Old 02-03-2021, 09:37 PM
Kuhtenia Kuhtenia is offline
Default Lycoming “O” versus “IO” Approved Automotive Fuels
Came across Lycoming Service Instruction No. 1070AB (dated 4/8/2020), “Specified Fuels for Spark-Ignited Gasoline Aircraft Engine Models” (https://www.lycoming.com/sites/defau...ed%20Fuels.pdf). [Document is technical and irrespective of separate FAA certification considerations.]
Question is this – For automotive fuels that meet Lycoming specs, Table 3 of the document ("Fuels and Fuel Grades Approved for Use in Lycoming Engine Models") includes many of the “O” variety engines, but relatively fewer of the “IO” engines. Is there a particular technical reason for this, is it more about what has actually been tested over the years, something else?
2022 dues paid
RV-6A Driver
Old 02-03-2021, 11:29 PM
skylor's Avatar
skylor skylor is offline
Default Compression Ratio
Most if the IO-360 series excluded from the auto fuel columns have higher compression ratios (8.7:1) than the O-360 (8.5:1). Th IO-390 which is also excluded has an 8.9:1 CR.
I’m not too familiar with the -540 models but I assume the IO models that are excluded is also due to higher compression ratio.
Skylor
Old 02-04-2021, 04:31 AM
Avanza Avanza is offline
Smile Automotive fuel
It is all about the copression ratio and the different combustion cambers.
If you are looking at the IO-360 there are two completely different engines.
1. the angle valve IO-360 compression ratio 8,7, 200 hp or more.
2. the parallell valve IO-360 compression ratio 8,5, 180 hp.
I have the parallell valve IO-360 compresson ratio 8,5, 180 hp and
using autofuel for more than 10 years with no problems.
This engine is also sold as the O-360 with carburator 180 hp.
Good luck
Old 02-04-2021, 05:33 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
By limiting timing at high MAP, you can safely run Mogas in any naturally aspirated Lycoming with standard compression ratios. You may have a loss in maximum power at higher manifold pressures but cruise performance should be unaffected.
This is best addressed with an EI having user programmable timing curves rather than fixed timing mags.
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 457.6 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
https://www.youtube.com/channel/UCiy...g2GvQfelECCGoQ
Old 02-04-2021, 08:16 AM
Raymo's Avatar
Raymo Raymo is offline
The Peterson STCs (one airframe, one engine) I applied to my Cherokee 140 (O-320-E2D) stated the primary concern with MoGas is vapor lock, which could be dealt with by turning on the boost pump.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 02-04-2021, 09:15 AM
Freemasm Freemasm is offline
Default Depends.
Haven’t read that particular STC; however, usually one each is required for airframe and power plant. Making a low wing airframe acceptable for Mogas is typically not a complex undertaking. A high wing often takes zero modification to hardware or operation. It is important to consider/differentiate between the two; AF and PP.
Old 02-04-2021, 09:45 AM
airguy's Avatar
airguy airguy is offline
For mogas, that's generally true - but for car gas with ethanol, caution is advised. The ethanol blends will not play nicely with natural rubber compounds in the fuel system like O-rings, hoses, bladders or diaphragms. You'll need to replace those with Viton or Teflon.
It's not actually the ethanol that attacks the rubber - but ethanol is an octane booster, which allows the refinery to start with a lower-quality base stock and still get to the same target octane after they add the ethanol. That lower-quality base stock has more aromatic hydrocarbon rings like benzene and related compounds, and those are what will attack the rubber.
Garden City, TX VAF 2022 dues paid
N16GN flying 1,000 hrs and counting on 91E10; IO360, SDS, WWRV200, Dynon HDX, IFD440, G5
Pending Repeat Offender - 10 kit is on order. TDI? Turbine? Stay tuned!
Old 02-04-2021, 12:49 PM
Smile Mogas with ethanol
Lycoming introduced fluorosilicone rubber in their fuelinjection 1987.
This is compatible with ethanol blended fuel.
I have a IO-360 parallel valve compression ratio 8,5, 180 hp.
Previously I had the Lazar electronic magnetoes with large spark advanse running with no problem. Now I have the Surefly (2) with 25 deg + spark advance up to 38 deg working fine.
I have not seen any reduction in power or increased fuel consumption.
There is about +5 F higher CHT compared to 100 LL.
CHT is around 320-350 F and never goes higher than 400 F.
Cylinders and pistons are very clean.
Mogas in EU may not be produced to the same standard as Mogas in the US.
Good luck
Old 02-04-2021, 01:38 PM
Yes Sir. My brief and poorly worded response was specific to the RVP property. The typical engine in the subject Piper has no problem with the lower Octane. As I’m sure you know, that’s only the half of it. Most people who’ve been around long enough have at least heard of improper use of Mogas/car gas/pump gas/. sometimes with very bad consequences. Here in the states (and probably everywhere) fuel is still the cheapest thing you put in an aircraft.
Old 02-04-2021, 03:17 PM
Thanks for the various pieces of information, all. Appreciate it.
2022 dues paid
RV-6A Driver
