Go Back   VAF Forums > Model Specific > RV-14
  #41
Old 12-21-2020, 06:48 PM
JDA_BTR JDA_BTR is offline
Took forever for the mail to deliver my new end caps from Rick Robbins even though he shipped mine a day before Billís. Got and installed them this evening. Perfect fit using the vans shroud. Couldnít be happier. I think that the vans end caps should not be used without great caution.
Ser 140142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
Old 12-22-2020, 06:12 AM
M McGraw's Avatar
M McGraw M McGraw is offline
Default 525 hours
I just finished an oil change and a very close inspection of the heat muffs because of this thread. I do remember having to adjust the muffs at about 50 hours because they moved around a bit. I now have 525 hours with no damage. However, it is now on my list of things to check at each oil change. Thanks to the OP for reminding us to look.
Marvin McGraw, 5TN4
RV-14. #140039 Complete
Flight hours: 750+
2021 Dues Paid
The Dues Paid note is a reminder for me
Old 12-28-2020, 05:09 PM
billybie billybie is offline
Default Turbo Heat
Maybe this is better?
https://www.aircraftspruce.com/catal...at05-15249.php[/quote]
I had numerous problems with my heat muff on my -7A. End plates kept cracking. Luckily, they never damaged the exhaust. Then I found Turbo Heat--great guy, he happily customized my heat muff to fit my setup (angled inlet port)--problem solved!
Billy Bie
RV-7A
Old 01-20-2021, 05:05 AM
RV6-KPTW RV6-KPTW is offline
Default I looked....
Add me to the list of cracked muff ends. I am at 85 hours and pulled the cowl yesterday for other tasks and found the forward muff end cracked in 2 places.
Click image for larger version
Dennis Callaghan (X26)
- RV14 sn:140193 - Awesome airplane!
- donation 11/27/2021 * 2
Old 01-20-2021, 06:41 PM
Richard Spatz Richard Spatz is offline
Default Double End Caps
Dennis,
I have had trouble keeping my heat muffs from moving because I can't keep them tight on the exhaust pipe. So I added a second end cap on each end of both heat muffs "back to back" to the existing end cap. This has stopped the movement.
Since they act like an end cap "doubler", I suspect they might also mitigate the cracking of the end caps? Cheap fix if it works!
Richard
RV-14A
Old 01-20-2021, 06:53 PM
The thing I didn't like with the Van's end caps when I first installed them is that they seemed to "give" and deform when the pipe clamp was tightened on the end. They just weren't really rigid in my situation. The new ones I got from Rick Robbins fit perfect, and rigidly clamped the pipe without any deformation at all when the pipe clamps were tightened.
It is possible with the Vans that I didn't spring out the little flanges enough to fit the pipe better. Perhaps with more understanding of what is wanted they would work perfectly. For me the Robbins caps worked much better without any fiddling.
Old 01-21-2021, 04:56 AM
I talked with Rick yesterday and ordered his end caps. I hope to have the same experience and will report back.
Old 01-25-2021, 09:15 AM
Lizard Lips Lizard Lips is offline
Mine failed after less than 50 hours. Looking back, the Van's end plates/muffs are very flimsy.
Joe R
RV-14A ... First Flight June 7, 2020.
Robinson R-22 Heli ..... Still learning!
Old 01-26-2021, 12:15 PM
mountainride mountainride is offline
Who can I contact to get the robbins solid ends for my existing vans muffs? I too have already replaced these and would like to get a better sealing muff.
-Jason
RV-14 N303XC : Flying
Old 01-27-2021, 05:16 AM
Rick Robbins contact info is in post #32.
