Old 09-24-2021, 10:28 AM
Larry DeCamp Larry DeCamp is offline
Default Common feed for ECU and COIL
Per Bob Nuckles today on aero electric digest, a common feed can cause dirty power and confusion in the CPU.
Larry DeCamp
RV3B sold
RV-4 fastback in process w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 09-24-2021, 11:00 AM
akschu's Avatar
akschu akschu is offline
I replied on that list. I think this is more complex than "shared bus bad discrete bus good." I suspect it has a lot to do with length and gauge of wire. What I don't have a good handle on is how much fuses/breakers/switches change this.
Terminating the ECU and coil at the end of 10" of 10gauge wire is no big deal, doing the same over 18gauge wire matters more, but probably still no big deal, but through 18gauge wire to a shared switch and breaker? I have no idea.
I do know that the backup battery shares the coil and ECU over 18G wire and a single fuse.
schu
