Old 06-01-2022, 06:40 PM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
Default No Digital Level?
Working on the RV14A fuselage. Page 29-06 calls for using a digital level to put a 10 DEG twist in the upper longeron.
Name:	plans 29-06.jpg
Well, I don't have a digital level. So how do I measure this? Let's see, what do I have that will give me a measurement? I do have a bubble level. I also have a very old carpenter's protractor that works very well. I also just so happened to have a metal shelf just laying around that happens to be perfectly square. I have tables that are perfectly level. Putting all of those tools together and securing with some clamps I came up with a system that looks like this:
Name:	Carpenter's protractor1.jpg
Name:	Carpenter's protractor2.jpg
After building the small wooden blocks called out in the plans I got busy twisting the longerons. I made sure the side face of the longeron was plumb, the metal shelf was level, and my protractor was set for 10 DEG. Twist away! A few more twists! Ok, a few more twists! Finally, we get:
Name:	10 DEG ready to go.jpg
10 DEG!
Digital Level? WE DON'T NEED NO STINKIN' Digital Level!
Name:	10 DEG on the firewall.jpg
RVBYSDI
Steve
RV9A
https://rvwings.com
Live Long And Prosper! 🖖🏻
Old 06-01-2022, 06:54 PM
There are several phone apps with that functionality.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 06-01-2022, 07:14 PM
RVbySDI's Avatar
Thanks for the info Kyle. I will look into that. However, I needed to keep working so this was the result of using what I had.
Posting this basically to say:
Think about what you are needing done and see if there is any other ways to accomplish your given task.
RVBYSDI
Steve
RV9A
https://rvwings.com
Old 06-01-2022, 07:20 PM
Working on my RV-3B project, I've concluded that two clamps per location is relatively secure. Sometimes one clamp will permit shifting. And those 3/4" Cleco side clamps are extremely handy.
Dave
Old 06-02-2022, 04:27 AM
plehrke's Avatar
plehrke plehrke is online now
You can always use trigonometry with a bubble level. If your bubble level is 2 ft long then 10 degrees is sin(10 deg)x24”=4.168” or 4 5/32 inches deflection at end of 24” level.
Philip
RV-6A - flying 1000+ hours
Paid dues yearly since 2007
There is something fascinating about science. One gets such wholesale returns of conjecture out of such a trifling investment of fact. óMARK TWAIN
Old 06-02-2022, 06:12 AM
Freemasm Freemasm is offline
Default yes, but
Always admiration for ingenuity. That said, bubble levels are notoriously inaccurate and often non-repeatable if not using the same side and direction each time. I've used my phone app when I could get away with it. As someone mentioned, a very useful and free tool. You'll need to brush up on your elementary trig as someone else mentioned. Now, save yourself some future aggravation and a lot of time and get a digital level. One with relative and absolute readouts is even better. Can make a lot of two-man jobs into one man jobs and the accuracy is much improved. They're pretty cheap and will pay for themselves in time. Before anyone says anything, the left full deflect was before shimming.
Best of luck, Sir.
Name:	left ail deflect 0.1.jpg
ID:	26569  Click image for larger version
Name:	left ail deflect 30.jpg
ID:	26570  Click image for larger version
Name:	right ail deflect.jpg
Old 06-03-2022, 02:42 PM
Skip12 Skip12 is offline
Smile No Digital Level
I didn't think I had one, but there's a free app for this...so now I have one (for free).
