Keep VAF
Going
06-30-2014, 10:58 AM
Open cockpit?
Is anyone doing an open cockpit RV3? I've seen a picture of a flying 3 in Hawaii I think. I'm day dreaming about my next project. I'm seeing an open cockpit and a Rotec radial....
Maybe a removable canopy aft section?
Bill Grischo, Phoenix AZ
N911WG RV-6A DVT
Flying, thinking about polishing
Reason: Added text
06-30-2014, 11:06 AM
Too much wind
My typical slow cruise speed which is hardly much more than an idle, "2000" RPM's equals 121 MPH !!!! Have you ever drove a motorcycle down the road at 85 mph that is a lot of wind even with a windshield your head would get beat up by the buffeting of the air at 121 MPH.
I have seen a few open cockpits in slower aircraft but that is not for me.
Robin Mckee
New Ulm, MN 56073
RV3b N219BB
420 hours and counting
06-30-2014, 11:26 AM
Like this?
I would want the full canopy so that I can use the aircraft most of the year. Too much that the aircraft can do that would limit it without the full canopy.
Gary A. Sobek
NC25 RV-6 Flying
3,500+ hours
Where is N157GS
Building RV-8 S/N: 80012
06-30-2014, 11:54 AM
The radial will have either a lower thrust line and longer landing gear legs or the top forward fuselage shape will be changed.
Dave
06-30-2014, 12:26 PM
The Bucker, a relatively fast Biplane, cruises at 115 MPH. It is quite pleasant for an open cockpit aircraft. However, it does buffet you some and it is quite exhausting on long cross countries.
The Bucker also has hinged side panels that shield you all the way up to your shoulders, so only your head sticks out. Something to consider; removable or hinged side panels? (you can't get in the Bucker with them in the up position.)
Google Bucker Jungmann and look at the images for ideas..
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
06-30-2014, 04:24 PM
Wow that open cockpit 3 is awesome .never saw one before
Adam Simmons
New Bedford regional airport commissioner
Future rv8 owner
Sonex 541sx
Loehle P5151
Fisher celebrity biplane
Challenger 2 (sold)
Challenger 1(sold)
06-30-2014, 05:55 PM
A lot depends on the windscreen. Shape, size etc.
My Skybolt cruises at 120 mph, calm as can be in the rear pit. VNE to 200 mph, could only tell by looking at the ASI, no noticeable difference.
I fly it down to 45° with no problem. Usually just wear my jeans and tennis shoes and medium jacket. If I fly longer than 45 minutes, I'll put on my flight suit as well.
Now if I stick my head out the side to look down...it gets breezy!
Doug
1947 Stinson 108-2
Steen Skybolt
05-09-2022, 10:53 AM
Google the N number of the open cockpit plane.
05-09-2022, 11:13 AM
The accident appears to have been caused by unrelated factors from whether or not the plane was being operated as an open-cockpit plane.
Dave
05-09-2022, 12:30 PM
Dave
Indeed.
https://data.ntsb.gov/carol-repgen/a...port/95386/pdf
Brian J.
Boston, MA
RV8 Based at ORH - Purchased
New Superior IO-360-B1AC2 w/Hartzell Composite CS
RV8 - #83313 - Under Construction (sort of!)
Thread Tools |
Display Modes |
