Gregg Brightwell
Ok guys, I know this should probably be posted in the RV4 forum, but since the same basic principle applies to the 3, 4, and 6, I put it here for a wider audience.
I would rather ask a stupid question, get laughed at, and get the right answer, than not ask and NOT get the right answer, so here you go:
You can see, that the distance from the bearing hole center to the torque tube hole centers, are NOT symmetrical. One measurement is 3.08", and the other is 3.4". This will surely change the geometry and associated aileron travel if installed incorrectly. There IS a right side up, AND an upside down, in other words.
So, I can't find anywhere, a dimensional reference that clearly, (or even vaguely) indicates which hole goes to the stick, and which one to the aileron. I feel kinda silly here, but I simply don't know. Have any of you had this issue?
