Gregg Brightwell
SO - you guys - I made posterboard templates for my aft floorboards. (The ones under the back seat) The templates fit fine, as they are flexible. When I made the "real" ones out of .025, they are a PITA to install. And that is without the stiffener angles. Will be even worse with them. The biggest problem is the front seat belt mounts are in the way. There is really no way to "bend" stuff out of the way.
I have done a search, hoping to find answers, but not what I was looking for. I do know, however, that I am dimpling the skins, and countersinking the structure under, to install flush pull fasteners, versus round heads. Nutplates are unnecessary, heavy, and time consuming. I guarantee, if I ever need to pull those aft floorboards, I can drill out those soft rivets, and reinstall the same, as fast as I can take out screws. (Especially since those screws are so easy to strip the heads)
A bit of a tangent there, but seriously, what is the trick to these floorboards?
Gregg
Gregg
