  #41
Old 03-13-2018, 07:28 PM
RandyAB RandyAB is offline
Originally Posted by rv6ejguy View Post
Here's a photo of the return fitting location on my RV10. Bulkhead fitting sealed with Earls Stat-o-seals on both sides.
Are they easy to retrofit on a quick build tank that is already sealed?
______________________
Randy P.
1st time builder
RV10 - QB wings and fuse. Working on cabin top
St. Albert, Alberta, Canada
Reserved:C-GRPY
Old 03-13-2018, 07:34 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
My wings were already built when I put my return fittings in. Unibit, vacuum cleaner through the sender hole with some 3/4 heater hose attached to grab the chips. Short wrench through the sender hole to grab the nut. Maybe took an hour to do both sides.
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 448.3 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
https://www.youtube.com/channel/UCiy...g2GvQfelECCGoQ
Old 03-16-2018, 06:23 PM
onebounce onebounce is offline
Originally Posted by steve murray View Post
This is what I did based on researching through various posts. Use this with caution as I have yet to install the wings to the fuselage.
Steve
Hi Steve - unfortunately your picture/link doesn't seem to show - can you re-post ?
Many thanks
Andy
Old 03-16-2018, 06:27 PM
Originally Posted by rocketman1988 View Post
There are photos and descriptions in my build log on this topic.
mykitlog.com
Search for Sunman, Indiana. I am the only one building here...
Thanks Bob - good to get a view of this. Looks like your return line entered the fuse near the top of the wing root - do you have any dimensions for the locations or a picture of the location ?
Many thanks, Andy
Old 03-16-2018, 07:25 PM
rocketman1988 rocketman1988 is offline
Default Pix
I will try to get some pix tomorrow...
Bob
Aerospace Engineer '88
RV-10
N464RL
Dues+ Paid 2020,...Thanks DR+
Old 04-03-2018, 01:38 PM
thoma015 thoma015 is offline
***this if for a RV-7***
So I finished my first (right) tank and I installed a 1/4 in return line (the same as the fuel vent line). Im assuming this is no good or is it ok with a IO360?!
Is it possible to just plum the other tank (left) with a 3/8 fuel rerun line and only have fuel return to this tank? IE is it possible for the engine to draw fuel from the right tank but return the fuel to the left tank?
If thats possible i could away placard the aircraft to run first on the left tank so it doesn't overfill.
-Hawk
Old 04-03-2018, 02:38 PM
rv6ejguy's Avatar
You should return fuel to the selected tank. The return flow at idle is around 99% or about 1 gal/min. The 1/4 inch return is probably ok if you avoid a lot of 90 degree fittings on the way to it.
Old 10-09-2018, 12:34 PM
BrianDC's Avatar
BrianDC BrianDC is offline
Default Sanity check
Ok, so I'm building my tanks currently and planning to add a return line as I'm planning on an EFII solution. (Figure I can cap it off if I change my mind later).
I'm pretty clear on where I need to put the return line (or where I shouldn't), but starting to doubt myself on how I'm putting it in. Currently I have an order into vans for two more of the VA-141 fuel flanges. My assumption is if the fuel supply is the same size as the return, all is good? A few posts in this thread are making me doubt myself. (maybe I misread and the concern was how to attach a VA-141 once the tank is sealed since it has to go on the inside?)
Any issues with putting two VA-141 flanges on the tank. One for fuel feed, one for return?
If I go with a AN bulkhead fitting (-6 or do I need larger?) I would need to make an anti-rotation plate for the inside of the tank, right?
Sorry for the possibly silly question.
Nevermind, looks like using another Fuel Flange (VA-141) and an AN816-6-6D Nipple should work just fine. At least that's what I'm doing for now.
Brian Lester
RV10 Slow Build - #41778
Finish Kit - in progress
RV10builder.com
KVKX / KHEF
