Back up solid state artificial horizon low voltage warning
sirlegin
I just replaced my alternator with a B&C and took out a Plane power.
On idle my back up RCA 2600-3 artificial horizon shows low voltage of 9.8. My D10 shows a charge rate of 14.3 volts from the alternator with no other electrical issues, full batteries. I switch to cross feed and voltage is fine. Bad wire, bad voltage regulator?
Any ideas?
