Keep VAF
Going
VAF on Twitter:
@VansAirForceNet
04-21-2021, 05:03 PM
Mixture bellcrank
Here's another small Gotcha. Photo=1,000 words
The C-670 Bushing is pressed into VA-165 Mixture Bellcrank.
When the bellcrank is bolted to VA-164 Mixture Bracket, it doesn't freely rotate unless the bolt is left loose enough so it rotates. The result is friction against the flanges. Not correct in my mind.
The bushing should be captured by the bolt between the flanges so the bellcrank can rotate freely on the bushing.
Maybe not the correct fix, but I drove out the bushing. Then the Mixture Bellcrank was reamed to 3/8" and polished. A tiny bit was removed from each side of the bellcrank so the bushing was a few thou wider. A bit of Lubriplate applied. Slip the parts back together. Now when the bolt is tightened, the bellcrank rotates either way freely.
Yes, I scratched it a little. I have touch up paint.
Edit...
Ditch the Vans bushing. Every time I reassembled and tightened the bolt, the bushing swelled and the bellcrank froze up. Go to the local hardware store aviation department and but a steel spacer bushing. I got one 1/4" ID X 3/8" OD and almost exactly the right length for less than $2. A little sanding and polishing and the bolt can be torqued to spec. Bellcrank rotates like butta!
Larry Larson
Estes Park, CO
E-mail: wirejock at yahoo dot com
Builder Blog: http://wirejockrv7a.blogspot.com
Donated 12/2022, plus a little extra.
RV-7A #73391, N511RV reserved
Disclaimer
04-21-2021, 05:15 PM
It won't show when flying...
Originally Posted by wirejock
Good catch Larry!!!
Don't worry about the scratches, how many times do I have to remind myself that I'm not building a 35000$ Swiss Watch...
...wait a minute... my project will cost way more...
It won't show at cruise speed and altitude...
Eric,
2023 =VAF= paid
RV-8 SB #83274
Grove Airfoiled Gear, Wheels & Brakes
VPX-Pro, EFII System 32, EarthX batteries
Aerosport IO-375, MTV-9-B/183
Skyview HDX
C-GEMQ, RV-8, "Dragonfly", flying
C-GNFJ, C72R Cutlass, flying
04-21-2021, 05:53 PM
Scratches
Originally Posted by riseric
Good catch Larry!!!
Doesn't bother me. That's for the builders that always comment about stuff that doesn't matter just to point out the mistake. Figured I would save them the effort.
Larry Larson
Estes Park, CO
Disclaimer
04-30-2021, 09:55 AM
Quick question, I'm also using a VPX will not be using the Garmin supplied shunt on the B lead... wonder what I want to measure with it? Thinking battery state charge / discharge, ideas? Single B&C 60a in my case.
Dave
RV7 Slider N732DH
YIO-360-EXP Thunderbolt
Garmin G3X panel w/VPX
Littleton, CO & KCFO (aka CO Air and Space Port)
Photo log: https://flic.kr/ps/9jjZz
06-16-2021, 09:58 AM
Looks like I get to move my throttle cable mount over... installed per Van's with stock exhaust on I(O)360-M1B...
Untitled by Dave Hock, on Flickr
This is too close and can't really even get the heat shield in place. I will attempt to flip the bracket over as others have done.
Dave
RV7 Slider N732DH
Reason: additional pic
06-16-2021, 03:43 PM
Something else to keep an eye on Dave is the two exhaust pipes where they cross underneath. Both mine and another -7 had made contact with one another and actually rubbed an oval shaped area. One of them rubbed all the way through and actually had a pin sized hole. Sent back to vetterman who took care of it.
Steve T.
CFII/MEI/ATP 737,DC-10
RV-7, Lyc IO360
AUO
06-16-2021, 06:16 PM
Thanks for the tip Steve
Dave
RV7 Slider N732DH
06-17-2021, 06:13 AM
Dave-
I had a similar problem and made a new bracket o replace the one Vans sent. The new one elevated the came up closer to the sump. You can see in your pictures there is some space available above the cable now. I used that to give me more room off the exhaust.
I made the new bracket first as a template out of 032 aluminum in order to get my dimensions right (took 2-3 trys), then ordered some 4130 (I believe I used .062) and mad it from that.
I don't seem to have any clear pictures of it on hand but I will be at the airport this weekend and will take some if you like.
-Ivan
Ivan Luke
Hope Valley, RI
RV-7 SB
Flying as of 9/13/21 (9 1/2 years!)
2022 dues paid
06-17-2021, 10:07 AM
Bracket
Originally Posted by Iluke
Dave-
-Ivan
I would love to see photos! Same problem.
Larry Larson
Estes Park, CO
Disclaimer
06-17-2021, 10:48 AM
Yup - same problem on my IO-360-A1B6; I also didn't like the angle/routing of the cable.
I did the same thing as prior poster -- make a new bracket out of 18ga 4130 plate. Move the cable hole over closer to the screw bosses and closer to the sump.
Brian Decker
RV-7 (Flying)
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
