Idler gear shaft torque value
terry.mortimore
Hi gang:
I'm starting the reassembly of my IO-320 after Divco did the repairs to my crankcase. The 1/4" bolts that hold the Idler gear to the case wore the threads out.
Divco has installed a 5/16" stud and the other hole is a 5/16" bolt.
I've had this problem twice and I want to make darn sure I get it right when it goes together this time.
I want to ensure I have the proper torque value for the 5/16" nut and the 5/16" bolt.
I see Service Instruction 1197A and 1310A referenced for this area, but I can't find a copy of these instructions.
Can someone point me in the right direction?
Thanks, Terry.
I'm about to do this this weekend. I plan on torquing to 17 ft/lbs for the bolt. Most manuals I find use 12 ft/lbs for the slotted nut.
My engine shop uses lock plates and a non slotted nut so I'm going to double check with them but they might do 17 ft/lbs on both.
Sorry I can't find either of those documents. Too bad, I would like to read them.
Hi Jereme:
I spoke with Divco and they told me 17 lbs/ft for both. I also found a more current overhaul manual online yesterday and it says 17 lbs/ft on the bolt and 12 lbs/ft on the nut.
I did the deed last night. I used the 12 lbs/ft torque on the slotted nut.
Terry.
Hi Jereme:
Terry.
Nice! If I recall those are wet torques correct? I seem to recall my engine shop guy telling me they put a "tiny bit of lubriplate" on the threads first.
Hi Jereme, I believe that those are lubricated torque values. I can tell you that mine were well lubricated with Red Loctite! :D
Terry.
Terry.
Haha nice. Ya that's probably not a bad idea. It would be no good at all if one or both backed out somehow.
