Originally Posted by Bud K
That link works. Looks like I may have to use a clamp on the cables like FlyBoy did since my cables are already routed.
Did you install footwells for the rear passenger? The -4 that I am looking at doesn't have them but I've seen RV-8 footwells installed in the -4.
I do not have foot wells but the angles supporting the bearing blocks are far enough forward so wells will fit aft of them should I decide to install them later.
I split the two nicopress sleeves with a dremmel and pried them open a tad to get them over the rudder cable. The cable to the pedals is 3/32”. I used tinned copper wire strands to take up the space between the 1/8 in. sleeve and the smaller dia. cable.
Clamps (a la Flyboys) would have been easier, but I had the sleeves and swaging tool handy.
