Old 01-18-2022, 03:55 PM
kjelle69's Avatar
kjelle69 kjelle69 is offline
Default Firewall weldments
Can these weldments be identified? New, old, reinforced?
I always check them for cracks or damage and it's easy since there is no insulation but still curious about which type it is?
________________________________________
RV-4. O-360A1D/180 with Pacesetter 200 Prop.
Old 01-18-2022, 04:34 PM
joeboisselle joeboisselle is offline
That's what I have, bought the kit in 2006. Blueprint page #27 shows the same.
Joe Boisselle
2010 RV-4
1941 Luscombe 8C
Old 01-18-2022, 04:49 PM
gasman gasman is offline
Looks like you may have a leaking fitting.
VAF #897 Warren Moretti
2021 =VAF= Dues PAID
Old 01-18-2022, 05:21 PM
kjelle69's Avatar
Oh, yes. This is a picture from 2012, these are repaired now. I had brake fluid all over the place in these days. :-D
Old 01-19-2022, 04:04 AM
kjelle69's Avatar
I looked up page #27 on the USB stick with the plans and it seems that some reinforcement is added on top of my weldments? The original bracket marked as "1" in my image is corresponding to the WD-403R in the plans but on top of that there is another thicker bracket marked as "2" in the image.
Also I cant see the longeron "3" in the plans.
Could it be so that the original builder put in these as extras since there is a O-360 engine in this machine?
ID:	21178  Click image for larger version
Old 01-19-2022, 04:52 AM
fixnflyguy fixnflyguy is offline
Default Repair/Mod?
Your weldments look to be reinforced/repaired/modified at some point. I have attached a picture of the late model/style weldments from my build in late 90's. The early weldments were "split along the corners, the newer ones are bent / welded pocket fittings.
Bill E.
RV-4/N76WE
8A7 / Advance NC
Old 01-20-2022, 10:01 AM
eisnerrv4 eisnerrv4 is offline
Default Hours
500 hours in 10 years. that's not bad. You're doing better than me.
Brian Eisner
RV-4 C-GRJT
Bedford Nova Scotia
Canada
Old 01-20-2022, 12:37 PM
kjelle69's Avatar
I am not really following you here ?
Old 01-23-2022, 10:08 AM
Vac Vac is offline
Kjelle,
You have the new style fittings.
Vac
Mike Vaccaro
RV-4 2112
Niceville, Florida
Old 01-23-2022, 07:57 PM
Stewbronco Stewbronco is offline
Default Nope he doesn’t
Those are reinforced weldements ….NOT the new style …..RVATOR had an article from VANS on that problem and fix on older style weldments ….I have lots of pictures of broken older weldments and the fix but can’t post them sorry
