Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Engine Monitors
Old 09-17-2021, 12:52 PM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Default Any one get GRT EIS to play nice with Dynon or Garmin G3X
I have a GRT EIS monitor which has it's own control and display head. The display is rudimentary but the control head has serial out that works with GRT EFIS displays....
Anyone able to get the the GRT EIS (Engine Indication System) to talk to the other EFIS made by Dynon or Garmin G3x?
George
Raleigh, NC Area
2021 Dues Paid
Old 09-23-2021, 09:46 AM
skylor's Avatar
skylor skylor is offline
It's unlikely that this can be done. The GRT EIS serial data does not follow any industry standard for engine data and since Garmin and Dynon have their own engine monitoring solutions they have no incentive to support GRT.
Skylor
Old 09-23-2021, 10:32 AM
Carl Froehlich's Avatar
But, you should be able to use the GRT probes and Fuel Flow sender with the Dynon EMS module.
Carl
Old 09-23-2021, 11:30 AM
N402RH's Avatar
N402RH N402RH is offline
If will connect and work with the Advanced Flight AF-5600 EFIS.
Rob Hickman
Advanced Flight Systems - Dynon Avionics
