Old 09-15-2021, 09:10 AM
Mdragon Mdragon is offline
Default Dynon Wifi, will an offbrand USB wifi work?
Just somehow lost my Dynon Wifi USB stick, was wondering if anyone here has tried a generic one and had it work. Debating ordering one off amazon.
Old 09-15-2021, 09:14 AM
N402RH's Avatar
N402RH N402RH is offline
Probably not, we have them in stock for $35
Rob Hickman
Advanced Flight Systems / Dynon
Old 09-15-2021, 09:22 AM
liuk liuk is offline
I never tried it, but I have seen discussion on this forum saying this model will work https://www.amazon.com/dp/B08F2ZNC6J...v_ov_lig_dp_it.
Old 09-15-2021, 09:53 AM
Have one coming tomorrow, will update if it works. Sure my other one will turn up somewhere.
Old 09-15-2021, 03:05 PM
climberrn's Avatar
climberrn climberrn is offline
Best way to find something is to order a replacement.
Joel
N626JA
RV-7A at CXP
Flying!
Old 09-15-2021, 03:15 PM
Joe Joe is offline
Default Edimax EW-7811Un
Originally Posted by liuk View Post
... discussion on this forum saying this model will work https://www.amazon.com/dp/B08F2ZNC6J...v_ov_lig_dp_it.
Yeah, that's what I've been using for a few years: Edimax EW-7811Un. The one from Amazon says "V2"; mine doesn't.
Joe Dubner
RV-8A
Independence, OR
Old 09-16-2021, 09:01 AM
Pdtofly Pdtofly is offline
Default EDIMAX Wifi Adapters
Both the EDIMAX 150 MB and 300 MB adapters will work. I have tested both in my system and they work fine. The 300 MB is Edimax Ew-7722Utn Ieee 802.11N - Wi-Fi Adapter
Brian
Old 09-21-2021, 09:49 PM
GeoffH GeoffH is offline
Did the EW-7811Un V2 work for you? I have a pair of these and the Dynon D1000 does not recognize them.
I've done some google searching and found the following. The Dynon Wi-fi adaptor has the FCC ID NDD9578221026
The Edimax EW-7722UTn v2 has the same FCC ID, http://en.techinfodepot.shoutwiki.co..._EW-7722UTn_v2
It does look very similar to the Dynon Adaptor https://www.edimax.com/edimax/mercha...ew-7722utn_v2/
Looks like Amazon has them here
https://www.amazon.com/Edimax-Ew-772...286840&sr=8-18
Old 09-25-2021, 09:43 AM
Default EW-7222UTN-IEEE-802-11N V2
I use the EW-7222UTN-IEEE-802-11N V2 on both my D1000’s Touches and they work just fine. I also gave a few to friends using the HDX, and they have no problems also.
