Go Back   VAF Forums > Education > Flight Testing
Old 05-10-2021, 08:50 AM
pvalovich pvalovich is offline
Default Split Flaps Flight Testing
After reading a recent Tip of the Week, during recent preflight of my -8A came up with the question of what would happen if for some unlikely reason, one of the flaps came loose while approaching or in the landing pattern.
Has anyone had any experience - or conducted split flaps flight testing?
Old 05-10-2021, 08:54 AM
gassman gassman is offline
My buddy had this happen in an apache. After takeoff he raised the flaps and one stuck for a little bit. He said one wing got really heavy before he discovered what was going on. He was just gonna put them back down before it popped up and all was well. I van imagine things would get very interesting in a full flap situation
Old 05-10-2021, 09:18 AM
chepburn's Avatar
chepburn chepburn is offline
First:
Do NOT try that.
Second:
Its not the same aircraft, (not even close really) but I did an accident investigation of a DHC-6 (Twin Otter) where the flap rod connection broke on final approach. This resulted in an uncontrollable roll and crash into the ocean. There will be a very high roll rate with one flap floating and one flap down. It is unlikely you will be able to overcome the roll rate with aileron even if you recognize in time what has happened to raise the lowered flap.
Chris Hepburn
Ottawa, ON
RV-8 C-GOGO FLYING
Renew 12/21
Old 05-10-2021, 09:41 AM
Tandem46's Avatar
Tandem46 Tandem46 is offline
Has anyone had any experienceÖ.
https://vansairforce.net/community/s...ad.php?t=35894
RV-7 Flying since 2004
1,200 hrs+
Old 05-10-2021, 04:04 PM
n82rb's Avatar
n82rb n82rb is offline
I had it happen in my twin Comanche on a go around one stuck about half way up. Luckily Comanche flaps donít come up really fast and I noticed the roll coming in as I brought them up and identified it immediately. I just stopped bringing them up and matched the m up and came around and landed.
Old 05-10-2021, 05:40 PM
flightlogic's Avatar
Default somewhat related
A build item to think about. I note that many builders have elected to use the solid HEX rod to push flaps down. On my 9A, I swapped them out after thinking just how fast that bird would roll, if a hollow tube collapsed or cracked at the threads.
I suspect if this occurred within 300 ft. of the ground, it would not be survivable.
"Kindness is never a bad plan."
exemption option waived. Donation appropriate.
Old 05-10-2021, 10:26 PM
JDeanda JDeanda is offline
Default Flap Asymmetry
I don’t know of anyone trying this on purpose. Doing so sounds a little like practicing bleeding. What actually happens depends how much roll authority is available at the current airspeed and configuration. I had a friend experience a flap asymmetry in a Grumman AA-5A Cheetah and he said it flew OK as long as he kept the speed down. He landed normally. I was in the back of a Lockheed C-5 one night that had an asymmetry. I noticed some rolling back and forth but the crew got it under control and we landed normally. They got on a maintenance stand and came down saying the airplane was pretty damaged and was headed off to a depot maintenance facility. My favorite was a Service Bulletin from Bellanca about breaking flap cables, which would allow the affected flap to retract violently. It said “This condition, while undesirable, is controllable.” My sense is that any of our RVs with their very effective ailerons and relatively high roll rates should be controllable with one flap extended, but I have no intention of trying it out on purpose. My CFI wife teaches her students to only move the flaps when the wings are level, just to hopefully make it easier to deal with an asymmetry.
Old 05-14-2021, 05:48 AM
chopperchops chopperchops is offline
My father had one stick full down on his twin Comanche on takeoff. Sadly it didnít end well.
PLEASE donít try this!
Rob Chopin
QB RV8
Wings done, fuse in progress.
Queensland Australia
VAF Dues 2021 paid-worth every penny!!!
http://www.mykitlog.com/ch0pperch0ps
Old 05-14-2021, 11:19 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Ever since I saw Paul’s (the OP) post, I have been thinking about how to do this testing, just to see what kind of rolling moment you’d get, and how much aileron it would take to counteract it. I suppose you could disconnect one flap and remove the pushrod, then use speed tape to tape the flap up (its going to want to trail in flight anyway). Then you get to altitude with flaps up, establish level conditions, and deploy just a tiny amount of flap and see the result. Add a little more, see the result. Record stick forces in roll with a fish scale maybe.
With a good test plan and safety analysis, you could get some great data for the community! Tip of the hat to Chris for the modeling, but in this case, I think you’d need test data to back up the analysis....which would be interesting to compare in itself.
WARNING - this is a thought experiment, and if someone would want to try it, they need to be a VERY experienced test pilot with a deep background in flight test safety!
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 05-14-2021, 11:33 AM
Mel's Avatar
Mel Mel is offline
Paul
AND A PARACHUTE! Of course, that would go without saying. This would already be on the checklist for an experienced test-pilot.
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished. Discount for Veterans, Law Enforcement, Fire Fighters.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
