Go Back   VAF Forums > Model Specific > RV-6/6A
Old 02-13-2022, 10:21 AM
CABaye CABaye is offline
Default GSA28 Roll Servo Install using Garmin Kit
Preface. The airplane is new-to-me and this is my first modification project.
I'm installing the GSA28 Servo using the Garmin Kit. If I understand the instructions correctly, the bracket is secured by fasteners penetrating the skin and sandwiching it to an external doubling plate (provided). If you have used this method; please comment on surface prep & finish for the doubling plate. Is any sealing recommended between the doubling plate and the skin?
I am replacing a Trio EZ-Pilot servo that was mounted to a tray that is about 1/2 inch above the lower skin. (see photo) I suspect that mounting the servo to the tray would invite geometry problems but would like the opinions of others.
Chris Baye, CFI
RV-6A, N2345PC (ex N125WH), KANE
Dues Paid 2021
Old 02-13-2022, 10:49 AM
Im looking at the photo and not sure if I understand how you plan to install the servo. Mine is a 9, so maybe different and mine was installed in the build - but it was done in the wing. Is this the center section? Is that where the servo is installed on a retrofit?
Sorry I cant be of more help but I am interested in learning something here! I hope someone who has done the retro in a 6 will chime in.
rockwoodrv9a
Williamston MI
O-320 D2A
Flying N376E
Old 02-13-2022, 12:40 PM
mfleming's Avatar
mfleming mfleming is offline
Looking at the Garmin manual 190-01115-01_ap it looks like your correct.
If it were me, I would not deviate from the Gamin instructions for the GSA28 installation.
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Empennage completed 11/2016
Ailerons and flaps completed 3/2017.
Wings completed 12/2017
Started on QB fuselage 01/2018
Sliding canopy mostly completed 10/2020
Wiring and Avionics harness completed 9/2/2021
FWF Started 9/3/2021
Donated for 2022 and so should you
