I recently completed an oil cooler airflow control door on my RV8, and immediately noted a reduction in #4 cylinder head temperature when the door is closed in flight. The oil cooler is mounted in the standard position aft of the #4 cylinder. Before the airflow control door was installed, the #4 cylinder has always been the warmest, sometimes 30 degrees higher than the coolest cylinder. With the door closed, the split is now 15-20 degrees warmer than the coolest cylinder (#2). It appears that the oil cooler "robs" enough air from #4 to make it run hotter. Has anyone developed a baffle system that causes the airflow to the oil cooler to be shared with all of the cylinders, and not "rob" it from just #4? Thanks for any suggestion!
