On my first few flights in my 7A, I had a heavy left wing. I squeezed the trailing edge of the right aileron and was able to trim hands free in cruise flight. The ball is centered with no trim tab on the rudder & the elevators are in trail with the horizontal stab in cruise. So I was pretty happy with the way it handles in cruise.
The issue I am having is now when I slow down, the plane wants to roll right(where it was rolling left before I tweeked the aileron). The slower I get, the more pronounced the roll to the right becomes. I have played around some with the right aileron trailing edge, but to no success.
I checked all the things that Van's recommends and nothing seems out of the ordinary. The only thing that may not be right on is when a digital level is placed on the horizontal stablizer, the right side is a couple of tenths of a degree higher. Don't know if this could cause the roll.
I would think that the faster I go the more pronounced an out of rig issue would be, but it seems to get worse ar lower speeds. It starts to roll to the right around 140 mph & the rolling tendency increases as it gets slower. Even with full flaps on final at 80 mph, it I let go of the stick, it will roll right. I have the manual spring aileron trim, but at the slower speeds it will not hold the trim. I'm just not sure what to check, any thoughts are appreciated.
Bob
Bob
