Old 01-25-2021, 06:39 PM
ssokol ssokol is offline
Default Avionics Bus Dropping Offline?
I tried to go for a brief flight this evening and found that gremlins have apparently invaded my electrical system. I last flew about a week ago - a brief 30 minute flight around the area. Everything worked as expected.
When I fired up this evening, the battery was a bit weak - took a few more blades than usual. I had done a bit of avionics testing and chalked the weak battery up to having used a few more amps than I thought.
Once the engine was turning as normal I flipped on the avionics master and... crickets. The avionics master controls an automotive relay that feeds power from the main bus to the avionics bus. (See the attached diagram.) Apparently the relay didn't close, so no juice to the avionics bus.
I snapped the avionics master back off and then turned off the master switch. The master bus remained hot (the alternator was live, and the ALT Field is controlled by a separate breaker). I snapped the avionics master back on and all the avionics went live.
Snapped the master switch back on, re-connecting the battery. Then I tried to turn on the strobes (powered from the master bus) and the avionics all went off.
I repeated this several times, and it seems that with the batter and alternator both connected to the master bus, any significant change in the load causes the avionics master relay to open - and remain open until cycled.
I shut down, pushed it back into the hangar and charged the battery for an hour. Tested everything off of the battery (engine / alternator off) and no problems: I could add and remove load without having any impact on the avionics relay. Everything worked as expected.
I hauled it back out, fired it back up (started immediately) and... same thing. Avionics don't want to come on line or stay on line.
I tested the relay and it checks out on the bench - closes at about 8v. Draws about 0.1 amp at 12v. No resistance on the switched path.
I tested the avionics master switch - grounds the relay coil as expected.
This same configuration has been working for about two years now with no issues.
Anyone have a guess what's going on?
Steve Sokol
Cedar Park, TX
RV-6A N101PR at 40XS
Open Flight Solutions - Maker Of FlightView EFIS
(VAF Supporter / Advertiser)
Old 01-25-2021, 06:50 PM
Jpm757's Avatar
Jpm757 Jpm757 is offline
Sounds like your automotive avionics relay is the problem, I would start by replacing the relay.
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017
(KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis, floats.
Building Javron Super Cub.
2020 dues gladly paid.
Old 01-25-2021, 09:18 PM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
^^^^^THIS^^^^^
I have a similar setup but with two automotive relays in parallel, each with it's respective switch. This provides redundancy in case one of the relays goes bad on me. FWIW, after 8yrs and almost 900hrs they are both still working fine.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2021 Donation made
www.PuertoRicoFlyer.com
Old 01-25-2021, 10:09 PM
PaulvS's Avatar
PaulvS PaulvS is offline
Try charging the battery for longer, i.e. overnight. Perhaps an hour on the charger may not have been adequate? Easy to do!
Paul vS (yes I'm also a Van)
Building RV-6A #22320 O-320 FP. Wings and tail complete, working on fuselage
Flying my Aeroprakt A-22 STOL and the aero club's RV-9A while I build
Old 01-25-2021, 10:25 PM
MCA's Avatar
MCA MCA is offline
Intermittent problems are always challenging.
At first blush this looks like a bad connection somewhere that has vibrated loose over the years. I've also seen bad switches that click but don't close the connection.
So possible problem areas include:
- bad relay
- bad switch
- loose switch to relay wiring
- loose bus wiring
Marc Ausman
RV-7 980 hours, IO-390, VP-X (sold)
RV-8 (flying a friend's)
Thinking about low and slow backcountry build.
Fly Navy!
VAF Advertiser - Aircraft Wiring Guide
Book to help with experimental aircraft wiring.
Old 01-26-2021, 07:40 AM
Mich48041 Mich48041 is offline
If there is no avionics bus, then it can not fail. Avionics in my plane are connected to the main bus.
Joe Gores
RV-12 Flying
Old 01-25-2021, 06:55 PM
rapid_ascent rapid_ascent is offline
Steve, This sounds like a head scratcher from your description. I think it would help if you measure the voltage on these different busses as you go through your testing. That additional information should help.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 01-25-2021, 07:11 PM
tthrew tthrew is offline
Default Voltage on main bus
Hi Steve, you need to know what the voltage is doing on the Main bus.
Also, I’ve seen poor connections do strange things. This will show up as a voltage drop or different voltage across a connection.
Tim
RV-7A N54LH O360 CS 1200+ Hobbs
Joined VAF 2015
2020 VAF dues Paid
