Old 09-05-2019, 08:29 PM
subpar_bucker subpar_bucker is offline
Default About to countersink the canopy front bow holes
Just want to double check because I cannot find this via google. The AACQ-4-4 rivet countersink angle is 100 degrees correct?
Old 09-06-2019, 07:57 AM
John-G John-G is offline
Subpar-
It has been a while but if memory serves me correctly, I believe the AACQ-4-4 rivet has a 120° angle.
You could easily verify that by countersinking a piece of scrap metal using a 120° countersink then cut it in half with a band saw .... then verify the sides of the rivet mate nicely with the sides of the countersink.
John
http://www.dogaviation.com/
RV-12 Wings, Empennage, Fuselage, Finishing, Avionics and Powerplant kits all completed
Now Flying!!
Donation paid until September 2021
Old 09-06-2019, 10:57 AM
JwWright57 JwWright57 is offline
Good suggestion John
Jeff Wright, Charlotte NC
Rv-12 started!
Tail 99% done
Wings 99% done
12IS fuse kit 99% done
Finish kit 95% done
Avionics kit 1% done
Dues paid 2020
Old 09-06-2019, 11:24 AM
dreed dreed is offline
big second on using scrap to verify. you can check the angle and get the microstop set perfectly
Dan Reed
Camas, WA
RV-7A - Slider in progress - N167DR (reserved)
Working on final assembly
2018/19/20 VAF dues paid
Old 09-06-2019, 12:30 PM
kkmarshall kkmarshall is offline
I believe all the pulled c/s rivets use a 120 degree.
Keith
329DR RV10-bought flying
Continually upgrading/tweaking
Old 09-06-2019, 01:59 PM
rcarsey's Avatar
rcarsey rcarsey is offline
I just completed this step a few days ago and I confirmed it was 120 degrees by looking at the datasheet for it.. I had the same question.
http://www.avdel-global.com/fileadmi...LQ_AACQ_mm.pdf
Rob Carsey, North Brunswick NJ
RV-12iS (N713)
Completed 10/2020
Dues paid 2020
Old 09-06-2019, 08:01 PM
Thanks for all the replies everyone!
Old 09-06-2019, 08:42 PM
AeroDog AeroDog is offline
Location: New London, NC (near Charlotte), Longmont, CO
If all the pulled CS rivets are 120 degrees, which rivets are 100 degrees? I'm thinking there may have been times when I used the wrong countersink cutter. Nothing ever looked wrong after it was set, however.
Jerre
Empennage, fuselage and wing kits complete
Canopy in progress, engine in the hangar.
RV-12 120593 N42KJ reserved
http://webpages.uncc.edu/~hill
http://jerre-hill.blogspot.com
=VAF= dues paid 2021
Old 09-06-2019, 09:58 PM
rv9builder rv9builder is offline
Jerre
Solid AN rivets are 100 degrees (AN426AD-3-4, for example)
Mark
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2020
Old 09-07-2019, 08:18 AM
Regarding the pulled rivets used on the RV-12 .... actually, there are some exceptions to the above statement. In particular, one that immediately comes to mind is the use of CCR264SS-3-2 rivets to secure dimpled nutplates ... their heads have a 100° taper. One example of their use is where a rivet squeezer does not have the clearance to squeeze a solid rivet ... such as the upper nutplate riveted onto the flange of a F-1215 seat rib.
John
Now Flying!!
