Keep VAF
Going
05-01-2022, 06:32 PM
Originally Posted by Planecrazy232
Walt,
I have the same prop on my 6A, O360. Mine is super smooth except for when I throttle way back in cruise, say to 11in mp. Definitely get good braking, but also feel vibration at that setting. Do you feel the same?
We’ll, I avoid low mp setting at higher airspeeds, driving the prop/engine with airspeed can cause piston ring flutter and may‘detune’ a counter weighted crank.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags, MTV-9 prop
05-16-2022, 03:49 AM
I just ordered a MTV-20-B/183-50 electric prop for my IO-360, lead time is 9 months, order in May, won't get it until February. I'm surprised they had one in stock when lead time is so long.
Why did you go with the three blade over two? My understanding is that weight is only 1lb less with 2 blades, and cruise is very slightly better with 2, while acceleration is slightly better with 3.
05-16-2022, 07:17 AM
The 3 blade is the only one that has been tested/certified on the high compression IO-370 engine.
Whirlwind, which I also looked at had the same advice 3 blade for the 370 was required.
05-16-2022, 07:29 AM
Copied Walt
As I tend to do, I copied Walt’s lastest upgrade. I flew out to 52F last week and installed the exact same prop on my plane (with Walt’s help of course).
I did a couple of local test flights then flew from Texas to Jacksonville, FL on Saturday. The prop runs very smoothly and overall there is less vibration. (Walt balanced both my old prop and the new one) There is a noticeable difference compared to the 2 blade Hartzell.
On the return trip I was at 7,000 ft where I was running full throttle 23.6 MP. I found that 2300 rpm was the sweet spot. My cruise speed was 159 kts which was maybe 1 less than the Hartzell.
Rick Aronow,
Flying 7A Slider;
RV-12 SOLD
Jacksonville, FL
Reason: Corrected MP
05-24-2022, 12:12 AM
159 knots? Is that with a O320? If it’s a 360, I would expect Full Throttle at 7000 to be 170+ knots..
Tom
Las Vegas
RV-4 flying…
RV-8 empenage finished 10-2020
Wings Started.. 11-2020
05-24-2022, 04:58 AM
True air speed
Actually, it’s an IO 370 with high compression pistons. For what ever reason, this is about as fast as my plane has ever been. I have not done any testing to see if there is an air speed error. However, when my IFR check was done, air speed was correct using the test box (we only brought the air speed up to something less than 100 kts). Ground speed correlates well with TAS.
Going from my original O 360 to the IO 370 increased climb performance but it only added a few knots of top speed.
Rick Aronow,
Flying 7A Slider;
RV-12 SOLD
Jacksonville, FL
05-29-2022, 08:56 AM
For those interested yesterday's flight at 7500' pretty well confirms no or negligible speed loss compared to what I was used to seeing on the Hartzell BA.
Note the RPM, would never cruise at that low an RPM with the BA, still smooth as glass and noticeably quieter!
05-29-2022, 10:39 AM
Cool
Very nice Walt....... I hear a lot about the MT smoothness and look forward to the experience in the near future.....keep posting your observations
Bob "Skyking" Corriveau
RV-8 QB Reserved N212KB
ATP
CFI/CFII/MEI
05-29-2022, 06:01 PM
Glad to hear it didn't significantly affect your cruise speed. While I have yet to try out my -8 at optimum cruise altitudes (7000 - 9000 MSL) with the 3-bladed MT, I really do like its climb performance as well as its smoothness and the aforementioned "airbrake option."
The only head-scratcher in my mind is MT's factory TBO recommendation(s), which seem largely based on time since manufacture rather than time in service.
John Newkirk
Wyoming Big Horn Basin/Colorado Front Range
RV-14A No. 140308 (N34PB) w/ 375+ Hours
RV-8 No. 83081 (N84TH) w/ 60+ Hours
Carbon Cub FX-3 CCX-2000 (N134PB) - SOLD
05-30-2022, 07:41 AM
I see 72 months or 2400 hours TBO in the manufacturer's booklet.
That's for a MTV-9-B/183-50a
Eric,
2022 =VAF= paid
RV-8 SB #83274
Grove Airfoiled Gear, Wheels & Brakes
VPX-Pro, EFII System 32, EarthX batteries
Aerosport IO-375, MTV-9-B/183
Skyview HDX
C-GEMQ, RV-8, "Dragonfly", flying
C-GNFJ, C72R Cutlass, flying
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
