Old 04-29-2022, 05:46 PM
Sdemeyer Sdemeyer is offline
Default Is this correct spacer?
Can someone confirm this is the correct spacer for a Sensenich 70CM6S prop?. It seems it should have lugs for each bolt rather than 2 alignment pins?
Thanks!
Scott
Scott DeMeyer
Olympia,WA
RV6A quickbuild, Flying as of 10-14-2017
Mustang II Built and Flying
Old 04-29-2022, 08:06 PM
VA Maule VA Maule is offline
It certainly looks like a Sensenich fixed pitch they just have 2 dowels , at lest all I’ve encountered.
Internet advice worth what you paid for it
edit: just noticed it looks like 2 spacers stacked together ?? I don’t know for sure but I doubt it’s wise or acceptable to stack multiple spacers!!!
Maule MXT-7(daily flyer)
Lancer 235(partner)
Raidial RV-8R Ephanage Done, Wings Done, Fuselage on it's tall Grove gear & engine hung
Old 04-30-2022, 06:25 AM
stneki stneki is offline
Looks correct to me assuming you are installing a Sam James long cowling.
RV7A Completed
N315S
Dues Paid
Old 05-02-2022, 05:15 AM
Byron7 Byron7 is offline
Default Spacer
Please put one bolt in that spacer. You will be upset when it falls on your toe. Looks good put rear spinner bulk plate on check for space to cowl and centre a little high to hood
Good job
