Well, here is my first maintenance issue. I am at about 65 hours on my new RV-7A. I was taking my wife up for her first flight in the new plane and on climbout at about 1500 AGL, all of a sudden I see oil spatters on her side of the canopy. Quickly throttle back, monitor oil pressure (which was good) and head to back for the downwind. Keep monitoring oil pressure (still good), hear the AFS 3500 tell me I'm approaching pattern altitude (I always keep it set at pattern altitude for my home airport unless on x-country's), turn base and land with no problems. Once in the hanger, I pull the cowl expecting to see a blown seal. Here's what I found.
Oil on the canopy
Grease coming out the zirc
Another zirc with cover forced off
Grease on the inside of only one side of the spinner
Called the local prop guy and he says that there is a service bulletin (Hartzel BA prop bought through Vans) about grease leaking. He says the bulletin informs that it usually happens after a plane has been sitting for awhile (do you think this plane has been sitting for awhile...I think not!). The prop guy also said that an o-ring or seal may have failed allowing engine oil to force the grease out of the zirc. The grease would have a greyish color if this was the case (he says). I looks original amber color to me.
I'll probably pull the prop and take it in on Monday. What are your thoughts as to the problem?
Oil on the canopy
