Old 02-21-2021, 08:46 PM
Sandrews Sandrews is offline
Default Hangar Cleanoutó Misc Items for Sale
Dynon Unheated Pitot/AOA. New. SOLD
Avery pitot mount. New. SOLD
Pitot static lines, T’s and static ports. New. SOLD
Delta Pop Aviation bent whip comm antenna. New. SOLD
Delta Pop Aviation ADSB antenna. New. SOLD
Delta Pop Aviation Transponder antenna. New. SOLD
Vans Grey seat belt set from RV6. $150
Garmin GTX 320A Transponder. $200
David Clark H10-13.4 headset. $200
Dynon EFIS D10. (Not D10A) $800
Click image for larger version
ID:	8618  Click image for larger version
ID:	8619  Click image for larger version
ID:	8620  Click image for larger version
ID:	8621  Click image for larger version
ID:	8623  Click image for larger version
Old 02-21-2021, 08:52 PM
Eric Minnis Eric Minnis is offline
PM Sent on the Dynon D10
Last edited by Eric Minnis : 02-21-2021 at 08:59 PM. Reason: since picture was added I see that is is a D10, not a D10A.
Old 02-21-2021, 09:41 PM
rvguy811's Avatar
rvguy811 rvguy811 is offline
Sent PM on Pitot mount and Seatbelts
I changed my mind on these items, sent you a followup PM.
John Hughes
RV-6 Built,finished in 2001, flown 750 hrs
(Regretfully Sold in 07) Based at CNO for 8 years :>))
Currently building another 6
Old 02-21-2021, 09:52 PM
johnbright's Avatar
johnbright johnbright is offline
Default three antennas and the pitot-static stuff
I'll take the three antennas and the pitot-static stuff. PM sent.
John Bright, RV-6A, N1921R reserved, at FWF
O-360, 8.5:1, vert sump, dual SDS EFI EM-5-F
links
Old 02-22-2021, 06:25 AM
jjbardell jjbardell is offline
Default Stuff
Next in line for the pitot static stuff and antennas.
Cheers, Josh
Building - Zenith 750 [11323] CruzerDuty27.5
N67LJ RV9-A [90504] - SOLD
N83LJ Sonex [0864] - SOLD
https://rvpilotlife.wordpress.com/blog/home/
Old 02-22-2021, 07:18 AM
Originally Posted by Gyrodoug View Post
I'm interested in the seatbelts please
Pm sent. Thanks
Old 02-22-2021, 02:57 PM
PaulRV6 PaulRV6 is offline
PM sent on Pitot/AOA tube
Old 02-22-2021, 04:02 PM
PittsCondor's Avatar
PittsCondor PittsCondor is offline
Default Avery Pitot Install
I will take the Avery Pitot install if it still available.
Pm on the way,
K. Register
CFI, CFII, MEL
RV7A - 2nd owner - Loving it
1941 Aeronca Defender - Sold - not missing it
Pitts S1S - Sold - missing it
Pitts S1C - Sold - missing it
Mooney M20C (2) - Sold
Cessna 172 - Sold
