Through the Texas freeze! Cleanup and caught up, here is updated info and Pics:
GRT WS w/ GPS module, NO AHARS or Magnetometer. EIS with MAP, Fuel Flow (FloScan), Oil Temp, and 4 Edo senders. 1: 0-2Bar, 2: 0-5Bar, and 1: 0-10Bar.
This was the engine monitor side of the panel in my -4. Everything worked 100% when removed, reason for removal was upgrade to G3X. I kept the Current sensors (Crazed Pilot), EGT, and CHT probes. 3 Harness's are included, both connectors on the EFIS and the Power / Data side of the EIS. I can throw in a bare DB25 for the EGT / CHT connector if you would like it. That being said, I would use the plugs but redo all the harness's just to clean them up.
$1000 plus actual shipping and they are yours. I had several PM's so if a couple people offer up, I'll take them in the original order of the PM's. Its the only way I can think to do it fairly.
Pics!
