Originally Posted by david.perl
Pressure came backup to 78/80 on retesting
phew, no need for new engine
David,
I'm late to this thread. Glad to hear that this worked for you. For those who worry about leaving grinding compound in the engine, I offer this tip. Decades ago, a customer brought me a Triumph Bonneville motorcycle which he had tried to "tune up". He had cross threaded the right spark plug which ruined the threads in the cylinder head. Normal fix is to remove the head and install a HeliCoil thread repair insert. I was able to successfully do the job without removing the head. I've also used this trick to lap the valves on a number of motorcycle engines.
Using a can of cheap shaving cream [foam style] and a rubber [vacuum hose] tube, I filled the affected cylinder with shaving cream. I then tapped the hole for the HeliCoil and installed it. HeliCoil inserts have a tang which must be broken off to lock the insert in place. This would normally fall into the cylinder.
The purpose of the shaving cream is to catch any aluminum shavings from the tap and to catch that SS tang. The shaving cream and assorted debris is then removed using a shop vacuum. You need to fabricate an adapter tube so that it will fit in the spark plug hole.
As shaving cream is merely soap, any residual cream left in the cylinder will do no harm. For anyone planning on using the valve lapping in place trick, I suggest doing the same. You even have two spark plug holes to aid in removing the shaving cream and any lapping compound from the cylinder.
Charlie K
PS I've used this trick successfully many times over the past 40 years. Also works great when someone has damaged a valve cover bolt hole on an engine. On cars, I cover the area with duct tape and cardboard. I then use the shaving cream to fill in any gaps in the cardboard. Then drill, tap and install HeliCoil as needed. Vacuum debris when done.
