Go Back   VAF Forums > Main > Safety
  #21
Old 01-21-2021, 03:18 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Originally Posted by Pilot8 View Post
What is Hartzell's position on nordocks?
There aren;t any washers involved in installing. Hartzell C/S prop - it doesn;t early have “bolts” exactly - more of a nut pinned on a threaded rod with a split pin. I don’t know where you’d put the Nordlock in this installation.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 01-21-2021, 03:48 PM
bjdecker's Avatar
bjdecker bjdecker is offline
https://www.nord-lock.com/insights/v...-lock-washers/
Ok, I'm sold -- I'll put these on my brakes and replace that AN5H that I keep forgetting to safety wire (shout out to Vic)
I dunno tho, without the safety wire holes in my fingers, how will I ever remember that I finished putting something together?
Brian Decker
Retired Firmware Guy and Airplane Builder
2020 RV-14 QB -- Under construction - Tailcone & Empennage Complete.
2018 RV-7 QB -- Built, Flying
2007 RV-7 QB -- Built, Drowned, Resurrected and flying
1998 RV-8 QB -- Started, Sold
1986 Mooney 205SE
1980 Mooney 231
Aided and abetted building a number of other RV's.
Old 01-21-2021, 03:59 PM
PerfTech's Avatar
PerfTech PerfTech is offline
...You have to un-pin the nuts and bolts from hub, then
reassemble them with the washers in place and re-pin.
I did a couple, seemed to work OK Thanks, Allan
Allan Nimmo
AntiSplatAero.com
Innovative Aircraft Safety
Products, Tools & Services
Info@AntiSplatAero.com
Southern California (KREI)
RV-9A / Edge-540
(909) 824-1020
Old 01-21-2021, 04:01 PM
Andrew Anunson Andrew Anunson is offline
Originally Posted by erich weaver View Post
Safety wiring my Whirlwind 200RV prop is a pain and I dread it. Is there any reason why Nordlock washers couldn’t be substituted?
Erich
Does your Whirlwind prop have an aluminum hub? If so, the Nordlock washers could work very well.
I don't think Nordlock washers would work at all with a one piece wood or composite prop since the hubs on these props can change with time and humidity (Isn't Catto and Hertzler now recommending belleville washer with their props?).
Old 01-21-2021, 04:05 PM
BillL BillL is offline
Dunno, but their position on safety wire is "option", they don't recommend it, but say it is ok for the airframe manufacturer to add the safety wire.
Bill
RV-7
Lord Kelvin:
Old 01-21-2021, 04:13 PM
That’s correct. I know, because my DAR made me look it up. Their manual, wrt safety wire, says, ‘Follow airframe manufacturer’s guidance’.
Old 01-21-2021, 04:23 PM
rvbuilder2002's Avatar
Maybe true, but I have worked with numerous Hartzell engineers doing propeller flight testing and I have never seen a single one of them take the option of not installing safety wire. Even when the prop was only to be installed for a couple of hours of testing.
Scott McDaniels
Hubbard, Oregon
Old 01-21-2021, 06:09 PM
Ironflight's Avatar
Yeah....but that is going to leave you a couple threads shorter on engagement on the prop flange bushings. I have no idea if that is OK or not - would want to see whomever designed the interface bless that configuration. There’s probably tons of margin - but the margin belongs to the designer, not the guy in the field!
Paul F. Dye
Old 01-21-2021, 06:48 PM
erich weaver's Avatar
The whirlwind prop also uses pinned nuts on studs, so the same concern regarding the degree of engagement would apply if Nordlocks were added. A call in to Whirlwind may be in my future.
Erich
Old 01-21-2021, 07:44 PM
emsvitil's Avatar
emsvitil emsvitil is offline
I would think the little wedges of the washer would eventually screw up the flat matting surfaces.............
Ed
