Keep VAF
Going
01-20-2021, 04:36 PM
It doesn’t make sense to me that inner tubes cost as much as the tires.
Dan Morris
Frederick, MD
PA28-140
Hph 304CZ
RV6 built and sold
N199EC RV6A flying
Retired Aerospace Engineer and A&P/IA
01-20-2021, 04:51 PM
Originally Posted by bobg56
I'm not trying to be cheap, just trying to get the best price possible, I can't see how an inner tube is worth $150, I'm thinking a little gouging going on...
Re-read post #2. Maybe El Niño affected the Michelin rubber trees...
Jim Stricker
EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 633
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father & CFI) - USAAF 1st Lt. Captain B-17H
01-20-2021, 05:20 PM
Not made from natural rubber. A comparable tube that doesn't say airplane is around twenty bucks.
01-21-2021, 09:21 AM
Of course gouging is going on... it's aviation related!
Michelin Air Stop tubes for bikes are less than $10 each. Go figure.
Chris Boultinghouse
Temple, TX
EAA 575512
01-21-2021, 11:24 AM
possible solution
This trick has not been applied to my tires. For some reason they don't leak and hold pressure real good.
But having been in construction for 41 years we have problems with leaks in equipment tires. Seems to stop leaks.
I have used sealer goop inside of my tubed and tubeless tires for quite awhile.
Use the correct amount and it slides around inside the tire/tube and seals as it goes. Just squirt it in through the core tube.
Ya I suppose it would freeze at altitude and make an out of balance unit. I don't know. After all it is water based.
If mine ever take to leaking. I can guarantee I will use it before paying $150.00 for a tube and less for the tire. live on grass so tires last a long time.
Art
01-21-2021, 12:14 PM
Repairs
I’m surprised that no one has mentioned the time, cost, and aggravation of repairing or replacing an damaged/destroyed wheel pant after a flat.
Something to consider in the cost tradeoff.
Dave
RV12 N951DZ
First Flight 9/23/16!
No paint yet. Working on a scheme with John Deere colors or accents.
01-21-2021, 12:41 PM
+1 on the Air Stops. One of those things that cost a lot and are worth it.
Dave
01-21-2021, 02:50 PM
I replaced my Michelin airstops tubes after 14 years. The were still holding air. Count on only topping airstop tubes a couple of times a year, other brands will require many more fill ups
Tom Martin RV1 pilot 4.6hours!
CPL & IFR rated
EVO F1 Rocket 1000 hours,
2010 SARL Rocket 100 race, average speed of 238.6 knots/274.6mph
RV4, RV7, RV10, two HRIIs and five F1 Rockets
RV14 Tail dragger
Fairlea Field
St.Thomas, Ontario Canada, CYQS
fairleafield@gmail.com
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
