Old 01-20-2021, 06:56 AM
1949MGTC 1949MGTC is offline
Default Bottom Rudder Fairing Advice
So I’m a newbie at fiberglass. What techniques and tools do you have for trimming the bottom rudder fairing down to the scribe line and how do you get it to be a perfectly straight line so it doesn’t look like a beaver chewed it?
Bill
S12049
140849
Old 01-20-2021, 07:53 AM
rocketman1988 rocketman1988 is offline
Default Permagrit tools
I use permagrit tools and they make f/g work much easier...
Bob
Aerospace Engineer '88
RV-10
Phase I as of 12-02-2020
Dues+ Paid 2020,...Thanks DR+
Old 01-20-2021, 02:16 PM
DRMA DRMA is offline
I found that a Dremel tool with a diamond cutting wheel worked best for me on the fiberglass cuts. Then I used the PermaGrit tools and a 12" piece of 2x4 with #80 grit sandpaper attached to it using double sided carpet tape to smooth and straighten the edges after the cuts.
Just be careful to protect your skin and lungs while you are making fiberglass dust (sanding and cutting).
Dave Macdonald
RV-10 First Flight April 1, 2020. Phase 1 Complete
2021 VAF Dues Paid (plus a little more)
Old 01-20-2021, 02:32 PM
bjdecker's Avatar
bjdecker bjdecker is offline
Sioux RS10K recip saw with 32tpi blades, and a 3M 5444 "Stickit" sanding board w/ 60 or 80 grit paper.
Click image for larger version
Brian Decker
Retired Firmware Guy and Airplane Builder
2020 RV-14 QB -- Under construction - Tailcone & Empennage Complete.
2018 RV-7 QB -- Built, Flying
2007 RV-7 QB -- Built, Drowned, Resurrected and flying
1998 RV-8 QB -- Started, Sold
1986 Mooney 205SE
1980 Mooney 231
Aided and abetted building a number of other RV's.
Old 01-20-2021, 04:54 PM
wirejock's Avatar
wirejock wirejock is offline
Default Dan Horton
Bill
S12049
140849
Best advise. Read every thread Dan Horton ever posted. Especially the Sticky on Fiberglass.
I made a feeble attempt to collect and share the high points. On my blog there are pages for fiberglass, paint, etc. Lots of lists of stuff.
I cut with a Dremel outside the line. Shape a little with a Vixen file then smooth with a board and 40, 80 grit. Dan's methods are awesome.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Disclaimer
Old 01-21-2021, 01:48 PM
agent4573 agent4573 is offline
I used a dremel sawmax to make the initial cut, then a piece of 60 grit sandpaper wrapped around a 1/2x1x12" piece of wood to sand the edge straight.
www.rv7build.com
2020 dues paid.
Old 01-21-2021, 04:13 PM
BillL BillL is offline
Dan would say the green 3m long board 40-80 grit lasts pretty well, I would agree. But, I switched to Permagrit for making a lot of plenums.
Pricey for a few uses but unbeatable for a lot of edges.
BTW - I use the dremel with HF diamond blades for well cured glass, for green glass a more coarse wheel is required.
If I built another plane, permagrit (or that style) countersinks would be purchased.
To the lower fairing, Vans has us put the attachment strip under the bottom rivets. I sanded the inside of the fairing to get the thickness even then added a spacer to avoid sanding the fairing to fit. Some outside (gel coat) sanding was done as the gel coat has no strength anyway. This way it was butted even along the length. The attach strip may have to be bent as the (my) fairing was not square. A lot of little fitting.
I saw one builder that split the fairing so the aft section could slide off (taildragger) and reach the electrical. I might try that on the next one too.
Bill
RV-7
Lord Kelvin:
Old 02-03-2021, 03:10 PM
8MikeXray 8MikeXray is offline
Default Best way to cut fiberglass
Use an oscillating saw with a 270 degree, round, fine tooth blade. Make a fence out of aluminum or wood, attach it to the fiberglass on the cut line with a hot glue gun and saw away. The kerf is 1/32”. Easy
I also used my Bosch oscillating saw to cut my canopy, works great and is very controllable.
https://www.boschtools.com/us/en/bos...tools-23521-c/
https://www.boschtools.com/us/en/bos...312f-142610-p/
MIke C
N68MX
RV-8 IO-390-EXP
A&P IA
ATP CFII MEI
