Working to rig the Aileron Trim Servo pull wires/springs and without the wings installed, need to know the left and right deflection angles of the control stick at the aileron stops as-assembles.
With full down elevator could someone with a 9/9A measure with an inclinometer, the max left and right stick deflection angles from vertical at full aileron stops?
Could also see what the stick angles are, with Neutral elevators, and Full Up elevators, just to see if there's much difference (however the plans say to rig with the stick full elevators down).
Knowing these angles, I can put the sticks at the stop positions, then set the required light tension on the servo springs.
Thank you!
Andy C.
Thank you!
Andy C.
