snoop9erdog
My question is what did you do to get the bottom skin to slide over the flap bracket in the notch of the skin and then still be able to slide the skin over the close clearance opening for the pitot mast?
Did you cut a slit in the small width at the skin where It would just fit around the flap bracket after already having slid the skin over pitot mast hole? Or another method? I’m finding that once I slide the skin in over the bracket I’m unable to slide skin cutout over the mast. Suggestions
