Go Back   VAF Forums > Main > Safety
  #11
Old 10-19-2017, 06:05 AM
BCP Boys's Avatar
BCP Boys BCP Boys is offline
Default thank you
This is the second Earth X battery meltdown in flight incident that I know of in 2 years. Please STOP putting these batteries inside the cockpit. I won't say anymore than that. If you want to purchase a Lithium battery for your airplane to save weight or any other reason, that is your prerogative, but for God sakes please put it on the other side of the firewall and not inside of the cockpit. Thankfully in both cases the pilots landed with no damage other than maybe their lungs, some avionics and some clean up inside of the airplane.
Great job managing a situation that I'm sure was extremely frightful. Imagine if there was no rear pilot or of this was an side by side where both people were effected the same rate.
Amir
RV-7 - Regretfully Sold (Currently in therapy )
RV-10 - Sold
Supporting VAF since the first visit
Old 10-19-2017, 08:01 AM
SgtZim SgtZim is offline
Thumbs up
Thanks for the write up. I think this is the first time I've heard of someone opening the canopy that far in flight - this is also a very good thing to know. I would like to hear from the pilots of that incident if they think the canopy would fairly easily open the rest of the way - for bail out purposes.
RV-8 slow build
IO360-M1B Sensenich fixed pitch
Garmin G3X
GTN 625
GNC 255
GTR 20
GTX 45R
G5 x 2
Facebook "log" https://www.facebook.com/BZsRVproject/
Old 10-19-2017, 12:04 PM
rgodsy's Avatar
rgodsy rgodsy is offline
I was going to have 2 EarthX batteries but changed to a Lead Acid for primary and Earth X as secondary, all FWF. You should look at Mike Bullocks runaway alternator issue to see additional considerations. If you take the battery out of the circuit by shutting off the master you will get a load dump into your panel. A lead acid battery makes a good load to help absorb a runaway alternator. You still need to provide a clamping circuit to hold the voltage down. But both provide a belt and suspenders for a runaway alternator. A lead acid battery will handle the runaway better than a Lithium battery.
Do not depend on a Lithium battery to act as an absorber for this. Over charging is one of the ways you can put your Lithium battery into thermal runaway. It can happen spontaneouslly too but that should be rare, most happen because of excessive charge or discharge.
I plan to monitor the temperature of my Lithium battery using a thermalcouple dedicated to it. Lithium batteries don't like to be charged when they are hot so I want to understand what temperatures it is seeing in the engine compartment. Especially when being charged.
Something else to consider. There are concerns about mixing battery technologies. Hopefully they can coexist if hooked together for short periods or primarily in the prescense of a good alternator voltage, where both can remain fully charged.
In my case if I see a high voltage on the bus, I'll take the Lithium battery out of the circuit first. Also I can switch either out of the circuit if the alternator goes to 0v. That way only one battery at a time is providing source to the panel if a loss of alternator occurs but I have access to both. I should have more battery to power the panel than I have fuel to fly.
Just some things to consider. I'm not a battery expert so take this as things to think about. I have been looking into this and this is where I'm at right now.
RV-7A N67RG First Flight 2/21/2019
Dual Garmin G3x Touch, GTN 650Xi, GTR 200, GMA 245, GMC 307, GTX 345R, G5 ....
Aero Sport Superior IO 360 M1S CS
Dues Paid for 2022
Old 10-19-2017, 01:37 PM
spatsch spatsch is offline
+1
I feel sorry that you had to figure it out that way but I thought that was extremely useful info.
Thanks for posting!
Oliver
Oliver Spatscheck
RV-8 N-2EQ -- flying 500+ hours
Fokker DR-1 N-22EQ -- under construction
http://www.spatscheck.com/oliver
