Old 08-11-2022, 01:41 PM
Sawtooth Sawtooth is offline
Default West System Alternatives
I know West Systems Epoxy seems to be recommended most often but are there others out there that are just as good? I like to help the little guys compete when I can.
Old 08-11-2022, 02:15 PM
David Paule David Paule is online now
I've been using p/n 01-07924 from Aircraft Spruce. I like it.
Dave
Old 08-11-2022, 02:24 PM
KenB's Avatar
KenB KenB is offline
I've used System Three and like it. I'm not sure it qualifies, though, as a "little guy".
Longmont, Colorado (KLMO)
RV-9 in process
Pietenpol Air Camper, flying since 2017
Old 08-11-2022, 02:34 PM
BillL's Avatar
BillL BillL is offline
Lots of good epoxy resins - - different properties though. I use West unless I need something it does not do (properties). I have used some of the following. Not nearly all they offer!!
Resin Systems
EZ poxy
PTMW industries
Warning: Reading selection specifications can make one dizzy.
Bill
RV-7
Old 08-11-2022, 04:34 PM
jrock836's Avatar
jrock836 jrock836 is offline
In the fiberglass boat circles Total Boat epoxy is pretty popular, along with West Systems..
Joe
2013 RV-12ULS
Fort Worth, TEXAS!
LSRM-A
EAA #1409566
Old 08-11-2022, 04:42 PM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default West Systems
Can't go wrong with West Systems. I also used some High Temp epoxy from Fiberglast when I made the plenum for my plane.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717AZ Painted and Complete
2021 Outstanding Workmanship Sun N' Fun
2021 Gold Lindy Grand Champion Kit Plane
2022 Copperstate Fly in Grand Champion/Best Metal
2022 Reserve Grand Champion Sun N' Fun
PilotjohnS PilotjohnS is offline
Default Aeropoxy
Aeropoxy 2032 is 25% stronger than West and has a higher Tg, glass transition temp(194F vs 139F). I used it for my windscreen and like it a lotion
John S
Dues paid 2022, worth every penny
RV9A- Status:
98% done, 2% left to go
Structure done (less gear)
Electrical/Panel done
Firewall Forward 95% done less baffles and airbox
Fiberglass 95%
Old 08-11-2022, 09:07 PM
RV6_flyer's Avatar
Default Total Boat Epoxy
One of my RV flying / building friends was a composite airplane builder before he discovered RVs.
He recommended Total Boat epoxy to me as equal to but lower price than West Systems Epoxy. My research shows that Total Boat can be mixed with West Systems and is the same strength. Total Boat can be purchased on Amazon or direct from manufacturer and is less money than West Systems.
A kit of Total Boat epoxy comes with pumps for less money than West System without the pumps. West Systems has been in metal containers but Total Boat comes in plastic containers.
Gary A. Sobek
NC25 RV-6
Flying
3,500+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 08-11-2022, 10:23 PM
scsmith scsmith is offline
We use Jeffco (now Rhino) 1307LV almost exclusively. It is much cheaper than West, and a much better resin system. We normally buy it from ACS. The specs are essentially identical to the European MGS 285 that is widely used for composite aircraft construction in Europe, at a fraction of the cost, and more readily available.
West has let me down enough times that it is banned from my shop. One of its main shortcomings is that it will cold-inhibit. You do a layup, and the shop temp is, lets say, about 60F. Before it cures, the shop temperature may drop to the low-mid 50s F. With West system, you will get a rubbery part. You can then post-cure it at whatever temperature you like, for however long you like, and you will never get a good cross-linked epoxy cure.
I've done layups with Jeffco 1307 down to the high 40s F, and although very slow, it WILL cure, hard. And with a post-cure in the 100F range, will develop full mechanical properties. I know. I've done test coupons.
The only other epoxy resin system we regularly use is for applications where customers seem ****-bent on painting our parts black or dark red, and we need a higher T_g. For those applications, we use a PTM&W system that requires a post-cure to 175F and has a T_g of about 260F. (again verified by test coupons)
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 700
also
1/4 share in 1959 C-182B (tow plane)
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2021
Old 08-12-2022, 06:41 AM
lr172 lr172 is offline
I bought a gallon kit of total boat epoxy. It is a west knock off and about half the price. Am told the formulation is identical. Has worked well and seems to perform exactly like west.
Larry
