Go Back   VAF Forums > Avionics / Interiors / Fiberglass > COMM
  #11
Old 07-04-2022, 07:22 AM
f14av8r's Avatar
f14av8r f14av8r is offline
Originally Posted by PaulvS View Post
Looking for feedback or pireps from anyne who may have experience with the above VHF comm radios, both of which use a 2 1/4" control head, a remotely mounted transceiver, dual channel scanning and built-in intercom. I am considering which to purchase for installation as the single comm radio in a RV-6A for day VFR use, alongside a Dynon Skyview 10".
I already have a V16 with Vega control head in the aircraft that I currently fly and generally the radio works fine and the control head is easy to see. However, the control head has only two knobs and therefore the user interface is a bit quirky for swapping active and standby frequencies and turning on/off scanning. I've tried to contact MGL via their forum and email and also the local Australian rep and there has been no response at all, unfortunately . Not vendor bashing, but support is an important factor.
I'm wondering if the Trig TY91 may be a better option for the RV, the main concern is it is almost double the price of the MGL radio. I also don't have any direct experience with the user interface or performance or support.
Paul.
I went with the TY-91 when I bought my S-2E. I wanted to replace both the radio and the intercom. The all-in-one TY-91 solution saved me space and a lot of time and wiring. It works great. I rarely fly with two people but, obviously, when I do the intercom is essential. I used a Sandia transponder and Echo UAT to get ADSB In/Out. Everything works great and was reasonably priced.
Randy King
Tampa (Wimauma), Florida
RV-4 N212CS (sold)
RV-8 N184RK (sold)
Currently flying a Pitts S-2E
Exempt and gladly donating anyway - Current through March 2025
Old 07-05-2022, 08:47 PM
n82rb's Avatar
n82rb n82rb is offline
The v16 interfaces with sky view fine. It uses the sl30 protocol. The freq push from skywiew works perfect, now. I was one of the first to interface av16 and skyview and found a bug on certain frequencies but they patched the code a day or so after I emails them. The only minor thing is you must adjust volume and squelch and other parameters through the Vega head. I love the v16 skyview combo.
Bob. Burns
