  #21
Old 02-18-2021, 04:59 AM
amekler amekler is offline
well,
we measured everything.flap rod was perfect. right control rod was 1/4 in short. left control rod was 1/8 in short.
corrected the lengths. replaced torque tubes and redrilled the new tubes
success. the rods clear the fuel pump but not my much.
Alan
Old 02-18-2021, 07:30 AM
Piper J3's Avatar
Piper J3 Piper J3 is offline
Question - now that you changed lengths of control rods, will there be a noticeable roll induced when you lower the flaps?
Jim Stricker - EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 650
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father & CFI) - USAAF 1st Lt. Captain B-17H
Old 02-18-2021, 08:18 AM
DaleB's Avatar
DaleB DaleB is offline
Not since he re-drilled the torque tubes. I did the same on one side of mine -- had to replace the torque tube, since it couldn't really be re-drilled. What you end up with is the exact same rigging and control motion, but the control rods are moving in the proper way.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 02-19-2021, 04:26 AM
I re-rigged and drilled new torque arms with the wings attached and flaperons set 1/8 inch below
Alan
