Old 01-29-2021, 09:21 AM
mike newall's Avatar
mike newall mike newall is offline
Default Narrow Deck V Wide Deck
We have been offered an O-540 narrow deck engine that is inhibited, around 900 hours and was sent to the shop for an IRAN 'overhaul'.
Any issues with this motor on an RV10 ?
It is a basic O-540 260hp unit out of a BN Islander, O-540 E4C5 which should convert easily to our spec.
Please discuss and advise, as it is being offered at a rather attractive price ;-)
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2020
Old 01-29-2021, 09:26 AM
No problem with a narrow deck other than there is a little extra work to make the standard baffle kit fit. I know several folks (including me) who have narrow deck -540's from BPE.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 01-29-2021, 09:58 AM
eastonale eastonale is offline
Default Narrow deck
I'll agree. I have a narrow deck built by Barrett on my -10 and the only hassle is tweaking the baffle kit. It's not that hard but a little time consuming. I think it specs a little lighter than the wide deck so you have that going for you as well.
Mark Easton
RV-10, done, but never done.
Portland, OR
2021 dues happily donated
Old 01-29-2021, 11:22 AM
lr172 lr172 is offline
Same here. No real issues other than a bit of baffling work to make it fit.
Old 01-29-2021, 11:34 AM
salty salty is offline
That's a carbed 540? What's it's HP?
Old 01-29-2021, 01:37 PM
It is now, but it will get FI, electronic injection etc etc etc
Donated in 2020
Old 01-29-2021, 04:18 PM
Vern's Avatar
Vern Vern is offline
Smile Narrow deck
Does it have the cylinder hold down plates and internal socket nuts holding the cylinders? If so, a cylinder change is a little harder in my opinion
I have a narrow deck O320 on my Hatz
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
Old 01-29-2021, 04:23 PM
sailvi767 sailvi767 is offline
I have a narrow deck in my Rocket. Some believe the narrow deck is stronger. Itís the preferred option for high performance versions.
G
RV-6 sold
F-1 Rocket
Old 01-29-2021, 05:23 PM
woxofswa woxofswa is offline
Mine is a Barrett narrow deck IO-540. I'm not a mechanic or engine builder but someone in a position to know told me when I was shopping that over the lives of a thousand engines, the ND's would have more cylinder base issues and the WD's would have more case crack issues but neither would be common or significant enough to specifically choose one or the other.
Myron Nelson
Mesa, AZ
RV-10 N24EV
KITPLANES Contributing Editor
Old 01-30-2021, 01:12 AM
kiwipete kiwipete is offline
Default Sump fitting
Mike
I brought a Aztec c4b5 and changed to d4a5 configuration.
Looking at the e4c5 spec it may have a different sump so you need to find out if it will fit the vans engine mount and cowl.
From the Lycoming operations manual-
Oil Sump (O-540, IO-540-C, -D, -J, -N, -R) – The sump incorporates an oil drain plug, oil suction screen, mounting pad for carburetor or fuel injector, the intake riser and intake pipe connections.
Oil Sump and Induction Assembly (Except O-540, IO-540-C, -D, -J, -N, -R) – This assembly consists of the oil sump bolted to a mated cover containing intake pipe extensions for the induction system. When bolted together they form a mounting pad for the air inlet housing. Fuel drain plugs are provided in the cover and the sump incorporates oil drain plugs and an oil suction screen.
I checked the parts catalog and noted any difference. In my case it was mounting ears and some studs for the prop governor.
As for narrow deck vs wide deck I was told by my engine shop to be more concerned about how many rebuilds the engine had.
Regards
Peter
RV7 G-PBEC Flying
RV10 Finishing
