Old 06-11-2019, 09:23 PM
Jim62 Jim62 is offline
Default Numatx C Frame
I'm looking for a C frame for a Numatix squeezer or a source for someone (particularly in Texas) that will make one. I have the plans for one but I'm not a great welder and my supply house can only order the steel in a 20' section and you only need about 5' to make it.
Any Ideas?
Old 07-09-2019, 09:52 AM
Keith Rush Keith Rush is offline
As I have never seen these plans and researching for my own build, I wanted to ask if this allows you to use the Numax to dimple skins instead of having to buy a DTDR2 or a traditional dimpler? If so, seems like you could save some money going this route.
Keith
Old 07-11-2019, 09:13 AM
ROTARY7 ROTARY7 is offline
Default Yes, the C-frame can mount the Numatx hand-held portion
Yes, the C-frame can mount the Numatx hand-held portion for dimpling skins. There are two different variants of c-frame plans: One for scratch building a complete frame, and one for modifying a DRDT-2 frame.
Mark Swinford
Aeronautical Engineer
RV-7 N65NX
Old 08-02-2019, 09:27 PM
klussman84 klussman84 is offline
Default ATS squeezer
Looking for feedback on the ATS C squeezer. Any feedback on the squeezer or the company selling them? For $550 for the set it seems to be a good deal compared to others.
https://aircraft-tool.com/shop/detail.aspx?id=ATS-114CK
Thanks in advance!
Barry
Barry Klussman
RV-10 Empennage Kit Builder
KFYG Missouri
Old 08-03-2019, 07:02 AM
jacoby jacoby is offline
Thanks in advance!
Barry
I?ve bought several things from ATS. No real complaints. I have their drill on backorder.
The description doesn?t mention whether or not it has a progressive action. I would email or call them to find out. I?ve read that some of the clones do not. I would not buy one that doesn?t. At full speed my cp-214 would be nearly unusable.
Other than that it appears to be missing the short stroke option that the cp-214 has. I?m not sure if all 214s have it or not but I wouldn?t say it?s a deal breaker to not have it.
If you do end up getting it I would get the adjustable set as well. It?s completely worth it vs washer shims. A 3? yoke is also nice to have. Ideally a no hole version.
Old 11-06-2019, 01:04 AM
Patrick14 Patrick14 is offline
Default C-Frame
Where can i geht the plans for the Numatx capable c-Frame? I am considering buying a Numatx Sqeezer. If i get along with a rivet gun, a Numatx and a self built c-frame for my future rv7-a, i would go this path.
Thank you,
Patrick
Old 11-06-2019, 10:17 AM
Thank you,
Patrick
Patrick,
PM me your email and I'll send you the plans for the C-Frame. The plans call for 3"x6" steel tubing which is not used much locally, but 4"x6" was readily available so the fabricator used that instead and it has worked fine.
Jim
Old 03-16-2020, 12:35 PM
Packetpusher Packetpusher is offline
Originally Posted by Jim62 View Post
Patrick,
Jim
I'm in the same boat hoping to get by with a Numatix and a rivet gun on an RV-14 and no DRDT. If you don't mind I'll drop you a line asking for the plans too.
Matt
Old 03-24-2020, 06:43 AM
fixnflyguy fixnflyguy is offline
Matt,
I we have a dimpler at 8A7 with your name on it from a builder that passed a couple years ago. See me or Larry B.
Bill E.
RV-4/N76WE
8A7 / Advance NC
Old 11-23-2020, 11:54 PM
Staunch111 Staunch111 is offline
Patrick,
Jim
Hi All, I have the NUMATX system, and am looking for the 'Drawing Sheet' / plans for the giant C-frame. They were avaiable through the NUMATX site (I hadn't looked for a while) but since NUMATX were aquired by another company I canot find a public copy of the plans. The giant C-frame enables you to rivet (with O deflection) c.f the DRDT-2 which cannot be used for riveting. Any asistance would be greatly appreciated. PS: I have emailed Mark Swinford but I am unsure if he still has his access to his old email address.
RV7 SB Tip Up -200HP -CS- Inverted
Inventoried - ready to build - for RTW
