Old 03-28-2021, 09:47 PM
Steve Melton's Avatar
Default AT-205 on engine mounts
So, I was spraying my daughter's car suspension system with AT-205 and I thought about my engine mount turning a dusty white so I sprayed them too. I don't know if that will get me to 3000 hrs on these mounts but we will see.
before
after
everything is looking good for a trip. I removed the inlet air dams and oil heat exchanger tape because it's warming now. it's time to rock and roll to tornado alley, Kansas.
Steve Melton
Cincinnati, OH
RV-9A, Tip-up, Superior O-320, roller lifters, 160HP, WW 200RV, dual impulse slick mags, oil pressure = 65 psi, EGT = 1300F, flight hours = 900+ for all
I was born an airplane nut. I have no explanation for it.
www.rvplasticparts.com
Old 03-29-2021, 05:09 PM
elev666 elev666 is offline
Steve , I should’ve been following your 3-D printer exploits closer, what are the printed towers on your intake ramps doing there ?
Thanks , Mr inquisitive !
RV 6. GARV
1946 C85 J3
RV 7 A project
Grounds keeper @ CKS9, 2020 dues gladly pd
Old 03-29-2021, 05:19 PM
those are cowl inlet air dams. they block cooling air going into the engine and allow for even CHT's. I flew with these all Winter. they were removed yesterday because it's warming now.
also, the AT-205 was allowed to soak the rubber engine bushing mounts for 24 hrs. I can't be sure but the engine seemed to have more flex during start up. at least the bushing didn't explode. I have no scientific data.
Steve Melton
Cincinnati, OH
