Old 03-25-2021, 01:02 PM
nohoflyer nohoflyer is offline
Default AOA vs stall warning
It seems redundant to have both.
I plan to fly IFR so I will get the heated Dynon probe. Since I can get one with an AOA sensor, why would i bother building the Van's stall warning.
Any thoughts?
RV-7A builder
A320 Capt at some airline
T-37/T-38/KC-135
C-177/172
Piper Warrior
2021 donator
Old 03-25-2021, 01:47 PM
219PB 219PB is offline
I did not install the Van's stall warning on my Dynon system.
Paul Bonorden
RV-6A Flying
My Builders Website
Victoria, TX
Old 03-25-2021, 01:54 PM
jcarne's Avatar
jcarne jcarne is online now
I installed it because the leading edge already came with a the hole in it. I tied it to a light on the panel as a backup.
Jereme Carne
PPL
RV-7A Flying as of 03/2021
Exempt but gladly paying!
Old 03-25-2021, 01:58 PM
scrollF4's Avatar
scrollF4 scrollF4 is online now
Moderator, Asst. Line Boy
There's no need for both, unless you just insist on both a belt AND suspenders like Justin Wilson. I omitted the stall warning vane. I installed the heated AOA/Pitot tube for my Skyview, and closed the stall sensor hole in my wing with micro, sanded it smooth. Like it was never there.
Scroll
Catch her on YouTube's "Because I Fly!" channel
Exemption waived.
Proud and grateful 2021 -=VAF=- Contributor
PS: I am not an influencer. I have no influence. Just ask my kids.
Old 03-25-2021, 03:46 PM
Carl Froehlich's Avatar
+1. The audio feed from the Dynon AOA is superb.
Carl
Old 03-25-2021, 03:48 PM
N546RV's Avatar
N546RV N546RV is offline
As others have stated, I didn't install the stall vane since I planned from the start to use an AoA system. I filled the two leading edge holes with NAS1097 rivets and sanded until they disappeared, and the access panel got riveted in place permanently.
Philip
-8 fuselage in progress (remember when I thought the wing kit had a lot of parts? HAHAHAHAHA)
http://rv.squawk1200.net
Old 03-25-2021, 05:37 PM
longranger's Avatar
I installed the stall warning vane (one-bit digital angle of attack sensor) as a backup to whatever other angle of attack system I choose when I plan the avionics.
Miles (VAF# 1238, Paid up as of 12/20)
RV-7 TU 904KM (reserved)
Construction Log
Empennage Album, Wings Album, Fuselage Album
Old 03-25-2021, 06:43 PM
Gary7A Gary7A is offline
I adjusted the Van's light to come on at 10 kts, and the AOA audio to beep at 5 kts above stall. I wanted both as most of my time and been rotary wing so never had to worry about stall, at least not at low speed.
G.R. Kohler
Ohio
