Old 03-25-2021, 04:34 AM
Tony Petrone Tony Petrone is offline
Default Tire pressure
What is the tire pressure for a RV7?
Old 03-25-2021, 04:41 AM
flysrv10 flysrv10 is offline
Here you go.
Name:	rv10 tire pressure.png
Old 03-25-2021, 07:15 AM
Sam Buchanan's Avatar
been here awhile
This will be a process of finding the optimum pressure for your particular RV-7. You will see RVers using pressure as high as 45 and as low as high-20's. Much of this depends on whether or not your RV is prone to gear shimmy during taxi. If not then the higher pressures should work fine. If shimmy is a problem, you might experiment with lower pressure which will either inhibit shimmy or move it to a speed that is less problematic. On my RV-6 I start out with 35 and air the tires back up in a few months when they are down to 28 or so. This has been my standard practice since I started flying this plane in 1999.
Sam Buchanan
RV-6
Fokker D.VII replica
Old 03-25-2021, 07:25 AM
Jpm757's Avatar
Jpm757 Jpm757 is offline
Every RV seems to have its own "sweet spot" for main wheel tire pressure, depending on several factors including gear leg stiffeners, tire size and gear alignment. I have experimented between 25-40 psi for my mains and have settled on 30 psi running 380x150 oversize tires with wooden gear leg stiffeners. I have a Flyboys Condor II pneumatic tail wheel which likes 45 psi. These pressures seem to work well for my bird, with no main or tail wheel shimmey . My mains will develop a shimmey over 35 psi, and a grooved runway seems to exaggerate the problem.
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017
(KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis, floats.
Building Javron Super Cub.
2020 dues gladly paid.
Old 03-25-2021, 07:52 AM
Walt's Avatar
Walt Walt is offline
If you run 25 I suggest you carry a jack and spare.
I run 45 all around on my A model.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 1900+ hrs, New Titan IO-370, Bendix Mags
Old 03-25-2021, 09:11 AM
XLS+PAT XLS+PAT is offline
I recently added some Bluetooth tire pressure monitors that I found on Amazon $54. I put two on my RV7 and gave the other two to my hangar neighbor who also has an RV7. You screw them on to the air valve.
Just did a tire and tube change and started out at 37psi. The tire monitors connect to an APP on my iPhone. It reads both temperature and pressure. I compared the reading against my regular tire pressure gauge and it seems accurate.
I did a test flight with two full stop taxi backs. When I got back to the hangar I checked the APP and it showed 40psi and a temperature increase of about five degrees C.
To add air to my tires requires me to take half of the wheel pant off to access the air valve. So far these monitors are working great.
Old 03-25-2021, 09:20 AM
RVDan RVDan is offline
I can attest to that. Was experimenting trying to solve a vib issue and lost a tire in landing when it slipped on the rim. The tire was still good but it went flat with a leak at the stem junction.
Dan Morris
Frederick, MD
PA28-140
Hph 304CZ
RV6 built and sold
N199EC RV6A flying
Retired Aerospace Engineer and A&P/IA
Old 03-25-2021, 10:01 AM
uk_RV9A uk_RV9A is offline
If I recall correctly the RV9 build manual specifies 25psi. Usually run between that and 30.
Old 03-25-2021, 10:24 AM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is online now
+1. This happened to me once. Since then I keep them at 40-42 and have not had a recurrence.
Low tire pressure to fix a shimmy is a bad bandaid at best. Balance the tires and for nose wheel guys use the very nice Matco axle instead of the stock set up: http://www.matcomfg.com/AXLEASSEMBLY...dv-3657-1.html
Carl
Old 03-25-2021, 11:34 AM
been here awhile
Yeah, but did you prime your wheels?
I knew this thread would prompt all sorts of blanket statements and dire predictions, these tire pressure threads are very predictable. But maybe the original poster can see that optimum tire pressure may be dependent on his particular RV-7.
Sam Buchanan
RV-6
