Old 01-30-2021, 12:35 PM
amekler amekler is offline
Default control rod scrapes the fuel pump
My flaperon control rod scrapes the fuel pump. (this is the updated fuel pump)
Any idea of how to remedy this?
Alan
N603NH(reserved) RV12 50% done?
Old 01-30-2021, 10:50 PM
Tacco Tacco is online now
It is a close fit. There are a couple of things to check. When I had this problem, I found my flap handle to control mixer connecting rod was not the right length. Also check the main flaperon tubes for the correct length.
Steve Morrow
RV-12 N12SM
Builder 121036
White Salmon, WA
2020 Donation Paid
Old 01-31-2021, 05:06 AM
Steve,
Will check. This is with the wings off. Does that make any difference?
I haven't set the the stabilator cable tension yet so the control stick moves a lot.
This is the updated fuel pump so I don;'t know if it is taller than the original pump.
Alan
Old 01-31-2021, 10:44 AM
Not having the wings on or the elevator cables tension should not make a difference in my opinion. I too have the upgraded pump. Once again, The length of the push rods, including the flap handle push rod are crucial. I'd remove them and measure them precisely. I assume that the interference occurs with the flap handle set in a detent (?) ... check it in all three positions.
The geometry is very subtle. But the length of the rods causes the two main flaperon push rods to sit higher or lower just slightly. That was my problem anyway. My flap handle pushrod was longer by an 1/8 of an inch and my flaperon push rods were also of just slightly. When I corrected these, the fuel pump interference problem went away.
Steve Morrow
RV-12 N12SM
Builder 121036
White Salmon, WA
2020 Donation Paid
Old 01-31-2021, 12:54 PM
thanks Steve will measure .
thought I followed the instructions
Alan
Old 01-31-2021, 09:09 PM
rvbuilder2002's Avatar
Alan
This is usually caused by the flapperon push/pull tubes being not quite the proper length when the flapperon torque tubes were originally drilled (if they are just a bit short the horns on the torque tubes will be angled fwd a bit too much which will cause contact when it pivots fully fwd.
Scott McDaniels
Hubbard, Oregon
Old 02-01-2021, 03:59 AM
Scott,
What's the fix? New torque arms?
Alan
Old 02-01-2021, 09:33 AM
DaleB's Avatar
DaleB DaleB is offline
Thatís what I had to do. Only one was drilled off from where it should have been, so I replaced that one. Problem solved.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 02-01-2021, 10:57 AM
NinerBikes NinerBikes is offline
Scott,
Alan
Sounds like a new torque arm or arms, cut to the proper, longer length.
Measure twice, cut once, is what we say in construction.
Donated
2012 RV-12, #212 N72DJ KWHP based.
Old 02-01-2021, 12:47 PM
Scott,
Alan
If you use care doing the drilling (since the holes in the inboard portion wont be smaller pilot holes anymore) you can just replace the outboard portion While being certain that the push/pull rods aren't any bit too short.
Scott McDaniels
Hubbard, Oregon
