Keep VAF
Going
12-17-2021, 06:33 PM
Originally Posted by Mikeyb
Eat your heart out panel guys!
I know that Mike built a very light weight RV8 with a constant speed prop. It is still possible especially when he selects a simple panel instead of a complicated full-blown IFR rig with a bunch of backup. This one should be a real performer.
RV8 standard build: 90% completed (90% to go)
Waiting to install wings to fuselage.
Days to Final Installation: 999
Days to AWC: 999
Days to First Flight: 999
Donation paid through 2022
12-18-2021, 06:51 AM
Boy, some of these -8s and -8As are really wide!
Tom
Las Vegas
RV-4 flying…
RV-8 empenage finished 10-2020
Wings Started.. 11-2020
01-23-2022, 07:20 PM
First time with all the fun $tuff in the panel. Just starting on the wiring.
Ken W.
Mount Vernon, WA
2022 VAF Supporter
01-28-2022, 08:50 AM
Wow. that panel on 804RV looks beautiful.
01-28-2022, 09:12 AM
Nice Ken, That has to be one of the most fun parts of the build.
Fastback 8
Fuselage in progress
02-06-2022, 06:11 AM
Not quite done but here is a custom extended panel that we made at my house to fit my set up.
02-06-2022, 06:12 AM
This was our mock up on cardboard. I made demential reps of the Garmin equipment to include the wire harness plugs!
02-06-2022, 04:28 PM
Chip, Hopefully you have sat in an 8, an extended panel makes it more difficult to get in/out of especially for taller folk. Also with the screen that low you will always be lookin down to see it. One of my main goals on all panels is to keep the screens as high as possible for better viewing.
I also noticed some large holes for wires in a primary crossmember, may not be a great idea at that location.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags, MTV-9 prop
02-06-2022, 04:43 PM
Also, the stick needs to go past the lower panel and if the panel is extended downward, the stick gets shorter. And I find it a little too short as it is.
Flying RV-8 N880BC
2022 Dues - happily paid.
02-06-2022, 05:38 PM
The panel is only wider in the center and not taller. The one additional hole in the cross member was approved by vans as it’s a small hole and grommet and I added a second brace. Good eye though. I have spent a lot of time in the cockpit and everything lines up well. This aircraft is an aerobatic plane so most of my flying is Outside. By doing the panel this way you avoid the horrible off set screen look.
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
