Old 12-14-2021, 04:11 PM
Rv8bill Rv8bill is offline
Default Determining wire length
Hoping someone can add some clarity. How is each wire size determined when smaller wires are connected to a larger wire and the wires are different lengths? E.g. A Landing light in each wingtip draws 7.5 amps. Wiring from each light is 12' long and terminates in the center of the fuselage, where they connect with a single 5' wire going to the switch. Total current draw is 15 amps. The single wire from the junction to the switch is obviously carrying twice the load. A single point ground will of course mean the ground wires will be of nearly identical length as their power counterparts. I can see a couple ways of doing this. Curious to know how others have done it.
Old 12-14-2021, 04:27 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
You would benefit from getting a copy of The Aeroelectric Connection. It gives all the needed info you are asking about.
http://www.aeroelectric.com/
I would ground locally for the wing tip lights----done it in the past and no problems.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 12-14-2021, 04:32 PM
rapid_ascent rapid_ascent is offline
I think you have answered your own question. Each wire has to be sized for the current it is carrying and the length it needs to travel. For my strobes for example I have a common terminal strip where all the wing and tail lights join. The current is then effectively combined and then those wires carrying the combined current have to be sized for that current. In my case I used AWG 20 for each separate circuit and AWG 18 for the combined.
The problem with this type of approach would be if the combined current is high enough such that you need a breaker that is rated higher the breaker rating for the smaller size wire. Then you could potentially have a short on one of the smaller wires and the breaker not pop. As long as the breaker is sized below the rating of the smaller wire you should be good.
Ray Tonks
2022 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
Sensenich Composite 3 Blade Propeller
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 12-14-2021, 05:37 PM
Freemasm Freemasm is offline
Default In short summary
As described, my understanding is your system isnít adequately protected. The wire gage requirements are the easy part. There are numerous nomographs available that will provide an easy answer based on amps, length, bundled/free air, etc.
Breaker(s) or fuse)s) are sized to protect the wire, not the device. You can replace the branch wires with an appropriate gage or reference the aforementioned book and install a fusible link as minimum or temporary configuration in the branches. Other choices but would require more rework IMO. If Iím misunderstanding your configuration/question, some of the very talented sparkles here will interject.
Old 12-14-2021, 05:51 PM
PaulvS's Avatar
PaulvS PaulvS is offline
Default How have others done this?
I am planning to run a separate power wire for each wing tip light back to the panel and a wig-wag lighting controller. Wig-wag is a good safety feature as it helps to be seen.
Paul vS (yes I'm also a Van)
Building RV-6A #22320 O-320 FP. Wings and tail complete, fuselage almost done, working on canopy.
Flying my Aeroprakt A-22 STOL and the aero club's RV-9A while I build
Old 12-14-2021, 06:35 PM
Mike S's Avatar
Senior Curmudgeon
I assume you are using the Flyleds setup?? This is what I used in the new plane, and I highly recommend them.
The WigWag switch is something new, looks like a great unit. I used the module located behind the seat, fed from a panel mounted rocker switch.
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 12-14-2021, 06:36 PM
Desert Rat Desert Rat is offline
The easiest thing to do is size all the wires for the total load which allows you to run them through one appropriate sized breaker. Not the lightest, but certainly the simplest both to fabricate and to troubleshoot on down the road.
Terry Shortt
AGI, CFI, CFII, MEI, A&P, Janitor
RV7 Empennage & Wing done
Fuselage in process
#72651
https://eaabuilderslog.org/?blprojec...t=all&listcat=
Old 12-14-2021, 06:51 PM
PaulvS's Avatar
Yep, I'm using the Flyleds setup. Mine is a 2-seater and the flasher module will be mounted on the sub-panel, hence the need to run a separate wire to each wing tip LED light. It's straightforward to size each of the wires and I think FlyLeds give some guidelines anyway.
