Old 12-10-2021, 11:16 PM
SPX SPX is offline
Originally Posted by BTG1996 View Post
Thanks Justin- so it's possible to load a flight plan from ForeFlight to the GNC 355 without the FlightStream? That would be great news! My plane went straight into annual after the install so I can't tinker with it for another week or so. I appreciate the guidance.
Yes it is. I’ve done it many times.
Paid, Jan 2022
Old 12-13-2021, 07:40 AM
BTG1996 BTG1996 is offline
Default Great news
Great news to start a Monday with. Thanks!
Old 12-13-2021, 02:34 PM
enterprise enterprise is offline
It cross talks with foreflight. When you update the flight plan in the 355 it will send it back to the iPad. I just flew with it yesterday. Loaded a LPV on the 355 and then went back to the iPad to pull up the chart. It was already in the foreflight flight plan so I just long pressed on the approach and hit show plate button.
I am redoing my panel from old Dynon D100/120 and G5 to full 3 screen G3X and I kept the 355 rather than swap to another navigator. I replaced a 250XL and needed the comm. Starting fresh, the 375 is hard to beat if you don’t already have a ADS-B solution. I really like typing my comm frequencies rather than twisting the dial.
I learned on the iPad simulator. Very handy. Also a good way to decide between the 3 models as you can see the display differences.
Matt
RV-10 Owner
RV-12is Builder
Old 12-14-2021, 08:51 AM
Longez's Avatar
Longez Longez is offline
Post
Matt,
Just in case you don't already know, the GNC 355 also integrates with the G3X Touch system as one of the fully supported COM radios that can be tuned directly from the G3X Touch displays.
See page 35-153 of the Rev. AP G3X Touch Installation manual.
Steve
Old 01-27-2022, 03:56 AM
mike newall's Avatar
mike newall mike newall is offline
Speccing the avionics for our RV10.
Already got Dynon HDX and it's autopilot/transponder etc.
Looking at a navigator - we currently have an Avidyne IFD440 and it is fine. However we only do 'light' IFR and don't need full VOR/ILS etc etc.
Looking at the pricing on the Avidyne compared to the Garmin GNC355, the Garmin is significantly cheaper.
Any issues with integrating the GNC355 with the Dynon and iPad for general autopilot connectivity ?
The 355 can be our second COM if we decide to go with the internal Dynon unit.
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2021
Old 01-27-2022, 09:27 AM
Tankerpilot75's Avatar
Tankerpilot75 Tankerpilot75 is offline
One thing I didn't realize that kind of bums me out is that you have to buy a $1,500 SD card (Flightstream 510) to have connectivity with ForeFlight and to get over the air database updates. I'm sure that's a known thing, but this is my first panel mounted GPS, so wasn't aware. Not sure if I'll do it or not, but seems like it would be a really useful add-on.
Do I understand correctly that you have to buy a $1,500 SD card to get database updates? I read where you can get ForeFlight to transfer your flight plan using Bluetooth so that’s good but database updates occur every 28 days.
I’ve currently got two non WAAS 430s installed and have been thinking about the 355 so an additional $1,500 data card on top of the $6,000 plus cost of the 355 could be a show stopper.
Comments
Jim Harris, ATP, T38, EC/KC-135A/E/R, 2008 RV7A, 2nd owner, N523RM (2015)
Superior XPIO-360 B1AA2, Hartzel CS prop, Dual GRT Horizon EX with ARINC, EIS, Garmin 340, 335 w/WAAS gps, Dual 430s (non-WAAS), TruTrak 385 A/P with auto-level & auto-trim, Tosten 6 button Military Grips, FlightBox wired to EX, Dynon D10A w/battery backup, 406 MHz ELT. Mountain High O2 system, CO2 monitor, Custom Interior, TS Flightline hoses, ETX900 Battery, Great POH!
Retired - Living the dream - going broke!
Old 01-27-2022, 09:57 AM
Jetmart's Avatar
Jetmart Jetmart is offline
Comments
Not totally correct. I think a misunderstanding of terms. The unit comes with a standard SD card that is programmable for both data updates and software updates using a PC or laptop. If you have a G3X it can be used to transfer a flight plan from ForeFlight or Garmin Pilot. The flight stream is required if you want wireless updates.
Glenn Martin
Windsor, Ontario
1941 Tiger Moth
2017 Waco YMF-5
RV-14 Kit # 140694 - First Flight June 22, 2021
RV-14 A - Kit Ordered February 8, 2022
2022 Dues Paid
Old 01-27-2022, 08:00 PM
Jpm757's Avatar
Jpm757 Jpm757 is offline
1 year subscription for 28 day update cycle is $299. SD card comes with the unit and is updated on FlyGarmin.com, takes about 1 minute. Software updates are free and also loaded using the SD card.
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017
(KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis, floats.
Current Project Javron Super Cub
Thank You Doug!
