Go Back   VAF Forums > Model Specific > RV-14
  #61
Old 12-23-2021, 03:17 PM
johnbright's Avatar
johnbright johnbright is offline
Originally Posted by ShortSnorter View Post
... If anyone does have interest in ordering the Robbins muffs, you have to email him as there is no website. Unfortunately I can't find the email address, but I'm sure someone on here has it.
Earlier post in this thread: https://vansairforce.net/community/s...5&postcount=32
John Bright, RV-6A, N1921R, at FWF
O-360, 8.5:1, vert sump, dual SDS EFI EM-5-F
Z101 as a template, links
Old 12-23-2021, 05:05 PM
ShortSnorter ShortSnorter is offline
Originally Posted by johnbright View Post
Thanks! Imagine that!
Ryan
RV-14 In-Progress
Build Site
Old 12-25-2021, 08:13 AM
JDBoston JDBoston is offline
We have noted a lack of longevity of the heat muff end ribs and it is currently being looked at by engineering.
More info when I have it.
In the mean time, be sure to do a thorough exhaust system inspection during each condition inspection in accordance with AC43.13 Appendix D.
Scott,
Was there an outcome from the investigation with engineering?
Thanks.
Jeff
RV-14A
Status: Tail mostly complete, Wings complete(ish), Working on: Fuselage Kit, Finish kit shipping soon! (EXP119), Engine ordered
http://vans14a.blogspot.com/
Old 12-25-2021, 02:08 PM
rvbuilder2002's Avatar
Originally Posted by JDBoston View Post
Scott,
Thanks.
I think one of the guys on the sustaining engineering team is working on this project now.
Scott McDaniels
Hubbard, Oregon
Van's Aircraft Engineering Prototype Shop
FAA/DAR
Old 12-28-2021, 07:44 PM
n982sx n982sx is offline
I checked mine when I first heard of the problem earlier this year but found no wear.
At the last annual however, two months ago, I found that the circular ends of the forward muff had cracked and needed to be replaced. I ordered new parts, including enough to do the rear muff.
The parts were backordered at the time, but they shipped about a month ago. When I rebuilt the muffs, I found no wear on the exhaust. It is on my list of items to check whenever the lower cowl is off.
450 hours on the old ones with no wear. We'll see how the new ones hold up.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 12-28-2021, 08:29 PM
bruceh's Avatar
bruceh bruceh is offline
I think you mean
14 CFR 43 Appendix D.
Bruce Hill
RV-9A N5771H flown over 900 hours!
APRS Tracking for KJ6YRP and Flying Over the Hills Blog
2021 VAF donator
EAA Tech Counselor, Pre Buys, Build assistance - canopy/tanks/fiberglass/electrical/repairs
Old 01-13-2022, 03:33 PM
Kedy.va Kedy.va is offline
I am installing the sleeves and I made a slider in one of the holes so that when I tightened them with the clamp it fits more
Old 01-26-2022, 02:02 PM
Driving '67 Driving '67 is offline
Default Joined the club
87 hrs TTSN Thunderbolt IO-390. Found doing annual. Aft muff assembly end broken Replaced end caps with Robbins product (great quality). Rest of the annual was good!
Click image for larger version
ID:	21494  Click image for larger version
ID:	21495  Click image for larger version
RV 14A
Flying!!!!
Serial 140118
Donation - 2022 gladly done!
Old 01-27-2022, 11:46 AM
BruceW BruceW is offline
Just make Rick Robbins the supplier to Vans for the end plates.
Bruce W
RV-7 QB (500+ hours)
RV-14 in waiting
Elk Grove, CA
Old 01-27-2022, 04:36 PM
mountainride mountainride is offline
This is the correct answer. The Vans muffs are mis-engineered and should not be installed. Mine failed under 100 hours. I believe he used to be the supplier before they were brought in house.
RV-14 N303XC : Flying
