  #71
Old 01-27-2022, 10:28 AM
chaskuss chaskuss is offline
Originally Posted by Shawn25854 View Post
snipped
This is the one I bought, a 12 volt, 5" linear actuator with feedback and 225lbs of torque/force. They are all made by the same company and different manufacturers apply their own label. Compare them all, it's the same actuator. snipped
Yes, the torque increases as shaft speed decreases. Obviously, it's the same motor. Only the gearing changes. Anyone know what the specs [speed/torque/distance] are on the original flap actuator sold by Vans?
Charlie
Old 01-27-2022, 10:45 AM
sblack sblack is offline
Originally Posted by Pat Hatch View Post
Hi Larry, position sensor is an internal potentiometer and works just like the Ray Allen POS-12 does except you don't need an external sensor. Easy to calibrate your flap position gauge on your EFIS. Internal stops shut the motor off at both fully extended and fully retracted. Motor does not keep running when it reaches the end of its stroke.
Install instructions can be downloaded from the web site.
Some builders have had to modify their actuators to limit max flap deflection to prevent the top of the flap skin from popping out from under the wing trailing edge such that the wing trailing edge gets bent in retraction. Can this be easily done on your actuator?
Scott Black
VAF dues 2021
Instagram @sblack2154
Old 01-27-2022, 05:04 PM
RVScooter's Avatar
RVScooter RVScooter is offline
Hi Greg, I sent you a PM with a couple of possible alternatives for you.
Hi Pat,
For some reason that PM you sent never came through. Could you try sending it again?
Greg
RV-8A Super Slow Build
Empennage - Complete
Wings - Work In Progress
Fuselage - On Order
Finishing - In My Dreams
Old 01-27-2022, 06:20 PM
Pat Hatch's Avatar
Pat Hatch Pat Hatch is offline
Originally Posted by RVScooter View Post
Hi Pat,
Greg, sent you both a PM and an email this time! Sorry for the mix-up.
Pat Hatch
RV-4 (Gone to RV heaven)
RV-6 (N44PH - Flying)
RV-7 (Sold)
RV-8 (Builder & Avionics Installer)
www.phaviation.com Trim Relay Boards/Flap Actuators
www.pathatch.com (Photography)
Track Me
