Keep VAF
Going
01-26-2022, 11:35 PM
Centre section hardware
Hi,
Could someone who has a wing kit please advise me the bag number of the Centre section fuselage hardware that includes the NAS 1307-50 bolts. I知 building a slow build fuselage while waiting for my Quick build wings and don稚 have the Close tolerance bolts needed to aid positioning of F-704ABCand D to the two centre section bulkheads. I believe they are included with the Quick build wings.
Hope that makes sense.
Mike
Empennage arrived
VS completed
Rudder completed
HS completed
Elevators completed
Quick Build wings, fuselage and finish kit deliverd
#140425
RV14 Kit sold sadly.
RV7 Empennage started Jan 2021
Donation paid 2019
01-27-2022, 08:29 AM
Inventory
Originally Posted by Mikeandmaz
Hi,
Mike
Mike
Download this spreadsheet. One of the tabs is a complete 7(a) inventory
https://drive.google.com/file/d/1k28...ew?usp=sharing
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved (3,000+ hours)
Empennage, wings, fuse, finishing kit done. Working FWF
Disclaimer
01-27-2022, 08:56 AM
Mike,
The bolts came with the fuselage.
Center section ships with slow build fuselage.
Hope it helps.
Boomer
Bruce (BOOMER) Pauley
Kathy (KAT) Pauley
RV 7A--"MISS MARIE"--- N177WD (SOLD FLYING)72742
VAF #582-----------------EAA LIFETIME MEMBER
EX -KC-135A -------------BOOM OPERATOR #3633
VAN'S FLIGHT------------#6930
RETIRED覧覧覧覧-Enjoying life
See you in OSHKOSH
http://www.mykitlog.com/users/index....ley&project=84
=VAF= 2006-2022 DUES PAID
01-27-2022, 09:08 AM
Interesting I'm building/built my slow build fuselage before wings and understood the close tolerance bolts came with the wing kit... I was going to buy QB wings originally but given all the delays on QB kits switched in Aug and still waiting on my slow build wings!+!+! They are supposed to ship this month after talking with Greg a few times on this... I hope so as I've run out parts and only think left to do on fuselage is install the windshield when it gets a bit warmer.
Dave
RV7 Slider N732DH
YIO-360-EXP Thunderbolt
Empennage 100% Complete
Slow build Fuselage 99.9% done
Garmin G3X panel w/VPX, wiring 99% done
Wings in process...
Littleton, CO & KCFO
Photo log: https://flic.kr/ps/9jjZz
01-27-2022, 09:41 AM
Inventory
Hi,
Mike
8 WING HARDWARE-1 *SUB KIT
BAG 1993-1 CNTR SEC. HDWRE MISC
AN3-6A BOLT
AN3-7A BOLT
AN3-10A BOLT
AN3-14A BOLT
AN4-13A BOLT
AN4-32A BOLT
NAS1304-50 HEX HEAD CLOSE TOLERANCE B
NAS1307-50 HEX HEAD CLOSE TOLERANCE B
BUSH BR-065X3/8X2.781 BELLCRANK BUSHING
AN426AD4/14 RIVET
Larry Larson
Estes Park, CO
Disclaimer
01-27-2022, 10:36 AM
Thanks Larry, and all other replies, that痴 a great help. I値l see if I can order that bag separately.
Mike
Empennage arrived
VS completed
Rudder completed
HS completed
Elevators completed
#140425
Donation paid 2019
01-27-2022, 11:24 AM
warning
Just a fair warning, those bolts fit tight. I had a hard time removing the bolts once i riveted these parts together. I would use lube and stuff. You might even consider putting the parts out in the sun and letting them heat up prior to trying to remove the steel bolts from the aluminum center section. Like I said, i had a hard time removing the bolts once the center section was riveted together.
John S
Dues paid 2022, worth every penny
RV9A- Status:
98% done, 2% left to go
Structure done (less gear)
Electrical/Panel done
Firewall Forward 95% done
Fiberglass 70%
01-27-2022, 01:21 PM
Bolts
A set of Buller spacers and some hardware store bolts work fine for lining things up.
Larry Larson
Estes Park, CO
Disclaimer
01-27-2022, 02:48 PM
AN1307-50
The AN13-7-50 and the AN1304-50 bolts came in the No:1993 pack.
When I installed my wings to set the incidence angle I used store bought bolts and ground a taper on the end at the thread location. This made it much easier to install these bolts and then remove them afterwards.
Gordon Griffin
RV-7A under construction
VH-NAK
IO-360-M1B
Catto 3 blade prop
01-27-2022, 04:18 PM
I think i am going to do the same thing, but also grind a cup in the end. This way, if I have to use a drift punch to remove, i can protect the surrounding aluminum in the spar hole.
John S
RV9A- Status:
Fiberglass 70%
Thread Tools |
Display Modes |
