Old 01-23-2022, 08:42 AM
scissg scissg is offline
Default Empennage Trim Kit
New builder here. Inventorying my empennage kit and see a small stack of aluminum (rectangle in shape) labeled "Empennage Trim Kit". Was wondering if this was extra aluminum that can be used to practice riveting, drilling holes, dimpling, etc.? Don't want to practice on a something needed later in the build . Thanks!
George
Old 01-23-2022, 08:48 AM
BOHICA BOHICA is offline
George
Elevator Trim Parts.
Rick
2021 Donation Made
RV-14A 140892 building
QB expected Arrival Sep '22- Jan '23
Old 01-23-2022, 09:30 AM
JeremyL JeremyL is offline
Not sure what plane you are building, but for mine (7) I never used any of those parts. They are from what I have heard, extra pieces vans sends incase you mess up something. Most probably really screw up the trim tab and some fabricate riblets. Personally, I wouldn’t use them for practice. I’d save them and did, to use during building, for fabricating stuff, using as a doubler incase you wallow a rivet hole while drilling the HS spar, etc. But, you could use them as practice if you really wanted to, or use the vans practice kits to mess with.
_____________________________________________
RV7A(in construction)
https://eaabuilderslog.org/?s=N524JL
Old 01-23-2022, 01:29 PM
mulde35d's Avatar
mulde35d mulde35d is offline
Yes, those are extra pieces of aluminum for you to do wish as you please.
Jon
RV-14A Sold
RV-10 Empennage - On Order
Wings - In Progress
Fuselage - On Order
Old 01-23-2022, 08:21 PM
Thanks everyone! I'll keep them set aside for the (fully expected) mistakes. I have Van's practice kits so will use them to refine my riveting techniques.
