Old 01-21-2022, 09:06 AM
SeanB's Avatar
SeanB SeanB is offline
Default Canopy Fairing and Sika
Hello,
I still need to build the fiberglass fairing for my RV7 (tipper) canopy. The canopy is bonded with Sika and there is a bead along the front curve, where the fiberglass transition fairing will be added. Any issues laying fiberglass over the Sika? I could remove most of it in that area if it's better. Also, does everyone add the small metal clips along the bottom of the forward canopy that get buried into the fiberglass fairing? I'd rather not.
Thanks for any help!
SEAN BLAIR V7
Colorado Springs, CO
https://eaabuilderslog.org/?blprojec...&listcat=&sid=
2021 VAF SUPPORTER
Old 01-21-2022, 09:18 AM
PhatRV PhatRV is offline
There is an RV builder who painted over the sika section without any debonding. I think he used the epoxy primer over the sika then painted over the area that was primed. If you are using epoxy then I think it should adhere well. Just to be on the safe side, you may also want to scuff up the sika
RV8 standard build: 90% completed (90% to go)
Waiting to install wings to fuselage.
Days to Final Installation: 999
Days to AWC: 999
Days to First Flight: 999
Donation paid through 2022
Old 01-21-2022, 10:26 AM
wirejock's Avatar
wirejock wirejock is offline
Default Windshield trim
I layed up the windshield fairing as one piece. It was popped off, finished then Sikaflexed in place. Two clips on the windshield. One each side. They are hidden under the trim.
I did it just in case someone, someday has to replace the windshield.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved (3,000+ hours)
Empennage, wings, fuse, finishing kit done. Working FWF
Disclaimer
